Anyway to change outside temperature from Fahrenheit to Celsius?
Discussion in 'Prime Main Forum (2017-2022)' started by kortik, Dec 30, 2017.
  1. kortik
    kortik New Member
    Seattle
    Any tricks to go from F to C. I am not used to Fahrenheit , Celsius makes more sense!
  2. Elektroingenieur
    2,515
    3,285
    Three Touring
    Subtract 32, multiply by 5, divide by 9.
    More seriously, the consensus, at least in this thread about the fourth-generation liftback Prius, which has a combination meter similar to the one on the Prius Prime, is that there isn’t a convenient way to change the outside temperature display from °F to °C. It might be possible to replace the meter circuit plate with the Canadian or European version; I don’t know if these are otherwise compatible with U.S.-specification cars.
  3. Prodigyplace
    12,608
    11,798
    Central Virginia
    It would likely involve firmware changes too. In fact the difference may be only in the firmware to reduce stocking different meter circuit plates.
    Toyota does not release their firmware except as patches to dealers to address specific safety or reliability issues.
  4. bwilson4web
    16,284
    Scanguage II
    fuzzy1, KK6PD, WilDavis and 1 other person like this.
  5. Elektroingenieur
    2,515
    3,285
    Three Touring
    It wouldn’t surprise me if there are only two versions of the hardware, for LHD and RHD vehicles, with the firmware loaded before the parts are distributed. There are different part numbers for the meter circuit plate in different markets, and I’d expect they come pre-loaded with the correct firmware. This avoids the need for dealers to do initial programming, which depending on the design, might have to be done over an interface like JTAG or I²C, rather than the CAN bus accessible to a Toyota Techstream diagnostic system in the field.
    Yes; that’s one reason I think the only alternative might be to buy the Canadian or European part. The hardware might be identical to the U.S. version, but it would have firmware that displays the temperature in the desired units, assuming it works at all.
    Prodigyplace likes this.
  6. Prodigyplace
    12,608
    11,798
    Central Virginia
    Canada uses the same speed, economy, and temperature units as Europe. That is why the big fuss over the early 2016 Prius that would not display Km/h. Toyota has said the only solution was to replace the car.
  7. Sid786
    Sid786 Active Member
    262
    148
    Cherry Hill, NJ
    Yes, unit conversion from F to C is an option and it was one of my query to one of the sales person, who showed me. It is buried in the settings.
  8. Tideland Prius
    16,582
    -40°C = -40°F
    -35°C = -31°F
    -30°C = -22°F
    -25°C = -13°F
    -20°C = -4°F
    -18°C = 0°F
    -15°C = 5°F
    -10°C = 14°F
    -5°C = 23°F
    0°C = 32°F
    3°C = 38°F (OAT display blinks at 37°F)
    5°C = 41°F
    10°C = 50°F
    15°C = 59°F
    20°C = 68°F
    25°C = 77°F
    30°C = 84°F
    35°C = 95°F
    38°C = 100°F
    40°C = 104°F
    Print and attach to dashboard :p
    Alternatively, just remember that 10°C = 50°F and add/subtract 9°F for every 5°C change in temperature.
    #8 Tideland Prius, Jan 2, 2018
    KK6PD and Prodigyplace like this.
  9. Prodigyplace
    12,608
    11,798
    Central Virginia
    In the US the temperature blinks at 37. I have sometimes seen it blink below that.
    I think you meant 10C equals 50 F.
    Tideland Prius likes this.
  10. kortik
    kortik New Member
    Seattle
    why does it blink? at 37F?
  11. bwilson4web
    16,284
    To trigger a cryogenic epileptic event?
    KK6PD and benagi like this.
  12. stevepea
    stevepea Senior Member
    535
    581
    For our International Members.. Look out the windscreen, and if the two egg yolks you placed on the bonnet begin sizzling, you know it's hot. If it turns into a small, white frisbee, it's time for the heater.
    All kidding aside, I hear you. It's little things like this that don't make sense. I recently posted wondering why you can set the dash clock to either 12hr or 24hr format -- but the nav clock only displays 12hr format. So yes, some things just don't make sense.
    pilotgrrl likes this.
  13. Tideland Prius
    16,582
    That's the air temperature at which black ice could form.
    Air temperature is taken at 2 metres above the surface as the international standard so that means it could be freezing or just below on the road surface. It's a reminder that just because it's above freezing, doesn't mean there isn't ice on the road.
  14. Prodigyplace
    12,608
    11,798
    Central Virginia
    Mine actually blinked at 32 yesterday
    BTW when I wondered about the blinking I referred to the electronic version of the paper documentation you received with your car.
    The manuals are not just supplied for added ballast or packing. They actually contain useful information about your vehicle.
  15. Tideland Prius
    16,582
    Doesn't it blink at any temperature below 37?
    In the Gen 2, it did... well that and you had the yellow/amber icon (road/snowflake) on all winter.
  16. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    It likes you.
    Or it warns you that black ice may form soon.
    benagi and Prodigyplace like this.
  17. Prodigyplace
    12,608
    11,798
    Central Virginia
    I thought it was to get you to read the manual.
  18. UltraJetRefill
    156
    93
    Tucson, AZ
    Is this true? Is this only for the Prime? I can't seem to find it in the settings of my Two.
  19. citiprius
    citiprius Active Member
    241
    238
    51
    2018 Prius Prime
    Don't do that, it will be colder outside once you change form F to C. Instead of 10, it will be -12, much colder :p
  20. virgoboi
    virgoboi Junior Member
    New York & Canada (Ontario, Québec)
    The Fahrenheit thing is driving me nuts. I think they did this on some of the units to drive the 7.4 billion of us metric system users crazy! Has ANYONE found a fix for this for real though? :ROFLMAO: And one that doesn't involve SARCASM? :mad:
    mountaineer and UltraJetRefill like this.
