Wierd problem in cold weather
Discussion in 'Prime Main Forum (2017-2022)' started by Lennyz1, Jan 4, 2018.
  1. Lennyz1
    Lennyz1 Junior Member
    Upstate NY
    We were out in Syracuse NY about a month ago doing some college visits for my daughter. Well we spent a couple nights in a motel and the first night we had ice and about 2 inches of snow. So I hit the Auto A/C and let the car warm up inside. It was about 15 degrees out and this did not really do anything with the layer of ice on the windows and the inside was still cold. So I started the car and placed the front and rear defrosters on as well as brushed off the snow. I confirmed the car engine was running and went back inside for about 15 minutes. We come back out to leave and the car is off and when I opened the doors the dome lights were very dim and still cold. I pressed the start button and got all kinds of warning flashing across the dash. I turned the car off and then back on and still had warning flashing. With the car on the A/C fan seemed to be running slow and as mentioned, the interior dome lights were very dim. I put the car into reverse to see if it would back out of the parking spot and it moved, but still no engine running. I put it in drive and went across the parking lot and no engine running and the EV indicator was off. I pulled out on the main road and accelerated hard and the engine came on. At this point the warnings were Hybrid system failure and collision system failure. We proceeded to our scheduled college meetings and found a Toyota dealer when we were done. We pulled in and they plugged in to mind melt with the car. In the end they had no idea and reset to 20+ computers. The warnings were now all gone and we were on our way and have had no issues since.
    Can anyone answer that if the front and rear defrosters are on high will the engine shut down when it reaches temp and allow the battery to be drained?
    I spoke to me regular dealer where I bought the car and they said that this specific problem should happen and since the dealer in Syracuse cleared the faults in the computers, that they cannot help me.
    A similar issue happened on my 2007 Pius and killed my battery doing the same thing when running the front and rear defrosters. Went outside and the cars engine was off and the battery was dead, except the car was warm inside on this one.
    49,399
    if the car is in ready, you shouldn't have any problems with the battery. if it is not in ready, the engine won't start.
    Lennyz1 and bwilson4web like this.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    could be because the key fob was not detected when you went back inside the motel and the engine immobilizer kicked in
    Lennyz1 likes this.
  4. huskers
    huskers Senior Member
    2,543
    2,486
    Nebraska
    Can answer but I have noticed that the car can warm up just using the battery and can warm up using the ICE engine. When a defrost buttons (not the big button on your desk that works) on the dash are used you are using ICE engine. So if your ICE engine as not on for some reason the battery was draining the whole time. (If warming with the battery you will see the fan thing lit up in the display of the car/battery working. If it is not lit up the ICE is running the heater). (You know after reading my post I have no idea what I was trying to say).
    Def a learning curve with this tech. And, in my case, a problem with old dogs and new tricks.
    Lennyz1 likes this.
  5. Mendel Leisk
    38,662
    See this, lol:
    Give up charging during winter? | Page 8 | PriusChat
    Did the dealership assess the 12 volt battery? They should have an electronic load tester, most do now. Google Solar BA5 for a DIY level tester.
    Lennyz1 likes this.
  6. bwilson4web
    15,513
    Perhaps you might update your profile with the model?
    Lennyz1 and Prodigyplace like this.
  7. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Ignoring the obvious typo, I am guessing you have some version of Prius Prime.
    Please update your profile here. I was getting ready to report this to get it moved to the forum for 2007.
    #7 Prodigyplace, Jan 4, 2018
  8. bwilson4web
    15,513
    For a Prius Prime, there is a documented case of NOT sustaining the 12V battery charge when on an EVSE. If these electrical loads are put on a Prime plugged into an EVSE, it will easily discharge the 12V battery.
  9. Lennyz1
    Upstate NY
    Sorry I did not have model in my profile. It is an 2017 Prime Premium.
    Ice was running when I walked away. Both defroster indicators showed on.
    Front and rear defroster were activated using buttons to the left of 11" touchscreen. ICE always runs when front defroster is activated this way in my understanding.
    Key fob was in my pocket so maybe the immobilizer shut off the ICE, but the A/C fan was still blowing (a little slow) and cold air was coming out.
    I do not know if the starting/auxiliary battery was actually low. I had no way to check. Interior lights were dim when doors were opened when we got into the car and defroster fan was running slow along with what seemed like every warning indicator was lit on the dash.
    I had about 10 miles available on the hybrid battery when I parked it the night before and the same 10 miles after all this warm up time with defrosters. Seemed like no energy was used from the hybrid batteries, which I though that when I first used the A/C button on the remote it would have engaged the heat pump to start heating the car and depleted some of my charge.
    Point of the 2007 Prius story, was that I had a similar situation where it also shut down and drained battery completely after starting and putting on defrosters.
  10. bwilson4web
    15,513
    Did you let the engine run by just setting ‘Front defrost’ and left it in ‘EV mode’?
    I notice this is more an engine warm-up and will then shutdown the engine and revert to EV mode. This is different than putting car in ‘HV mode.’ Regardless, it should be easy to reproduce.
    Just to confirm, the portable charger was NOT plugged in?
    Lennyz1 likes this.
  11. Lennyz1
    Upstate NY
    Pressed the start button, turned on both front and rear defrosters, went back inside where is was warm. Did not look at what mode it was in.
    Prime was left in charge mode. The last few miles in the interstate highway before we got to the hotel, I put it into charge mode which is why I had 10 miles left on EV battery. I do not remember changing to EV or HV. I will have to check to see what happens when you shut it off in charge mode and then restart vehicle to see what mode it is in. It was the first time I had used the charge mode.
    It was not plugged in. No accessible charge points.
    bwilson4web likes this.
  12. bwilson4web
    15,513
    Good. I’ll try to replicate when I get home.
    Lennyz1 and priuscatprimeguy like this.
  13. bisco
    49,399
    always turns on in ev mode.
