Regular Unleaded
Discussion in 'Gen 2 Prius Fuel Economy' started by Cheap!, Jul 10, 2006.
  1. Cheap!
    Cheap! New Member
    1,157
    Ok,
    I can't seem to find it on the web or here. Do any of you know it there is any brand of gas that is not E10 still for sale in the US? Please help all of us get better Fuel Economy so we can use less fuel, and thereby decrease our emissions.
    Again, I am looking for unleaded without ethanol.
    If you could please post Brand (Exxon, Shell, etc...) and the type of unleaded they sell and I will do the same.
  2. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    That depends on your state. Mid Wes corn belt you got E10 24-7. We have it in winter here in Washington. All of that may change as EtOH replaces other oxygenation agents in gas.
  3. legalize freedom
    legalize freedom New Member
    But is there a company that doesn't add ethanol at all?
    legalize freedom!
  4. trvlnagain
    trvlnagain New Member
    There is an Exxon station in Lakewood, CO that advertises non ethanol fuel It is about 15 cents a gallon more than gas at other local stations...
    <div class='quotetop'>QUOTE(Cheap! @ Jul 10 2006, 03:39 PM) [snapback]284082[/snapback]</div>
  5. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(Cheap! @ Jul 10 2006, 05:39 PM) [snapback]284082[/snapback]</div>
    Your logic is faulty.
    It is true that your MPG will be less with E10. About 3% less from what I've read. Therefore, you will burn more fuel.
    However, E10 contains 10% less gasoline than straight gasoline. So, you are acutally burning less fossil fuels by using E10 than you are by using straight gasoline. Even though the car may emit more CO2 because you are burning more fuel, a smaller percentage of it comes from fossil fuels. The rest comes from the ethanol which was produced from corn which actually removed the CO2 from the air in the first place. Even if you consider the fossil fuels used to grow the corn, you are probably still consuming less fossil fuels than you would have if you were burning straight gasoline.
    So, if you do succeed in finding a gas station that will sell you non-ethanol gasoline, then you will actually be burning more fossil fuels and adding more greenhouse gasses to the environment than you would if you just used E10.
  6. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(Marlin @ Jul 20 2006, 02:02 PM) [snapback]289501[/snapback]</div>
    Is my understanding wrong too?
    I have heard from News and others that it takes about two gallons of fossil fuel to produce one gallon of Ethanol. So if you put in ten gallons of E10 you have really just put in eleven gallons of fossil fuel. Nine gallons regular unleaded in the tank and two more gallons to produce the one gallon of Ethanol.
    Is that true? I would really like to know. If it is true, it would create jobs but at what cost to the environment?
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    EDIT: Sorry bad information, post removed.
    tumbleweed
  8. meezercat
    meezercat New Member
    115
    Marathon used to be 100% gasoline, but I'm not sure if they still are.
  9. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(Cheap! @ Jul 20 2006, 04:43 PM) [snapback]289570[/snapback]</div>
    It depends on who you listen to.
    One study that seems to be quoted by lots and lots of people is by a UC Berkley professor who claims that the amount of energy required to produce Ethanol is about twice that contained in Ethanol. And technically, he's right.
    However, that number includes the solar energy used by the corn plant to grow the corn. It's not exactly fair to include that, don't you think? Would you include in the energy cost of gasoline, the solar energy required to grow the plants 10 million years ago that were turned into oil? How about the geothermal energy required to compress and heat the plants as they turned into oil?
    When you consider only the fossil energy input, which is after all what your original post was concerned about, then Ethanol is more efficient than gasoline and actually has a net energy gain, while gasoline has a net energy loss.
    Study: Ethanol production more energy efficient than gasoline
    <div class='quotetop'>QUOTE("St Louis Business Journal Article")</div>
    See Also...
    Energy Balance/Life Cycle Inventory for Ethanol, Biodiesel and Petroleum Fuels
  10. tumbleweed
    4,067
    692
    Eastern Oregon
    <div class='quotetop'>QUOTE(Marlin @ Jul 21 2006, 05:35 AM) [snapback]289864[/snapback]</div>
    You are right on Marlin. I originally posted the results of a "study" which was done by a Cornell professor named David Pimental. I deleted it after checking some of his facts (should have checked first). He stated that it would take 140 gallons of fossil fuel per acre for a farmer to grow corn, I have friends involved in agriculture and they tell me this is about 10 times or more to high. Also his "study" completely ignored the other by-products you can get from corn when you make ethanol. People on the other side of the issue tell me there are by-products such as corn flour, corn oil, corn meal and even grits. Other by-products are animal feeds such as Fibrotein TM, corn gluten meal and feed and certain amino acids.
    The truth is there are people pretending to be objective and knowledgeable on both sides of this issue who are being paid to come up with specific results, and they do. The only thing we can know for sure is that it is very political and there is a lot of money on both sides.
  11. Cheap!
    Cheap! New Member
    1,157
    It sounds like groups fighting for the future Dollar. One reason I don't drive an EV is because I need to travel 1000 miles or more before returning home sometimes. That is why I have a Prius. If I could plug it in, I would use it as an EV during the week without having to buy two cars. I can't wait until we can all travel around on power from the sun with a range of several thousand miles. However, then they will charge us a sunlight tax or a battery tax or maybe even a breathing tax that will be the equivalent of what we pay for fuel now. (So much per mile) :angry:
  12. tacomel
    tacomel New Member
    152
    <div class='quotetop'>QUOTE(legalize freedom @ Jul 20 2006, 06:34 AM) [snapback]289274[/snapback]</div>
    All of the Phillips 66 stations I've seen in southern Wisconsin have "no ethanol - better MPG" or something to that effect on their signs. I do not know what, if anything, this means in your area of the country.
  13. tmgrl3
    tmgrl3 Member
    315
    All my stations in my area on Long Island, NY, say "no more than 10% ethanol."
