Anecdote: Successful Cold Winter Fuel Economy
Discussion in 'Prime Fuel Economy & EV Range' started by Oniki, Jan 8, 2018.
  1. Oniki
    Oniki Active Member
    652
    499
    Colorado
    • How cold ? into the low 20s F. The ICE coolant is at about 32F according to the smartphone app 'Torque' after a cold soak.
    • Climate: Pretty dry (I think below 30% humidity usually) on a cold but sunny day
    • I drive about 45 miles to work, and then 45 miles back 12 hours later.
    Windshield fog/snow/ice: Typically only in the morning. I scape, squirt ~ 50% Isopropyl alcohol, and if needed scrape again. Then I flow cold outside air on to the glass to keep it low humidity until the ICE is warm enough to heat the cabin.
    How Successful ? 90 mpg (and one full battery charge) for 90 miles. This is way reduced from the ~ 110-120 mpg I see in 70F weather but still quite impressive for an ICE car. I've been able to reproduce the fuel economy through the past week. Go Prime !
    Please share successful winter driving strategies. So far as I can tell, Isopropyl alcohol is benign towards the environment, but please let me know if there is information that says otherwise or if the chemical is bad for the windshield wiper tubing. I do intent to keep a squirt bottle in the car, if for no other reason than to clean the rear glass.
    #1 Oniki, Jan 8, 2018
    Arctic_White and HPrimeAdvanced like this.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    I use a hairdryer to thaw out the front windshield instead of remote climate because remote climate is not as efficient as a hair dryer directly on the windshield plus by not using remote climate I skip the subsequent battery charge that occurs after remote climate is used. I'm paying my landlord $15.00/mo for the unlimited use of his electrons so I'm going to milk the system for all it's worth.:D:p
  3. Mendel Leisk
    41,334
    Be careful with the hair dryer, use it gradually; could it crack the glass?
    I supposed hot air from the vent system on the inside isn't that different though.
    priuscatprimeguy likes this.
  4. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Can you break down the EV/HV miles (i.e., how many of the 90 miles are in EV)?
  5. Tideland Prius
    16,549
    That'll be my concern too but as long as he's not directing the hot air to a specific place for a long time (long being relatively here), he should be ok.
    But yeah, I've seen people crack their windshield using the defroster.
    HPrimeAdvanced and Mendel Leisk like this.
  6. Oniki
    Oniki Active Member
    652
    499
    Colorado
    Tesla Bjorn demonstrated in a Video just far powerful the warm airflow in the Telsa is by directing it towards the windshield covered with ice ... and cracked the glass.
    Poor guy. All in the name of video blogging.
  7. Oniki
    Oniki Active Member
    652
    499
    Colorado
    No idea, since I don't use my EV miles uninterrupted during the drive. I can look at the EV miles/kWh readings if you are interested but they are influenced by overall elevation decline one way and rise the other way.
    My only reproducible data point compared to summer is from always leaving home on EV for at least the 16 miles or so. In the summer SoC would drop ~ 30% while in the cold winter SoC drops ~ 40% for the same distance. I think this SoC drop is influenced by starting out with a cold motor, tyres, etc since the final one way commute over 45 miles is better than the first 16 miles would suggest.
  8. stevepea
    stevepea Senior Member
    535
    581
    Other than "Move to California"? :)
    (Hey, one bad winter storm is apparently what got my grandfather to move to Calif from the east coast years ago...)
    Nice to see the Prime does well even in cold weather!
    HPrimeAdvanced likes this.
  9. Weasle543
    Weasle543 Member
    55
    Ohio
    Bjorn already had a rock chip in his windshield when he did that.
  10. Oniki
    Oniki Active Member
    652
    499
    Colorado
    My fuel economy has improved a bit of late while the weather is the same.
    I now consume about 0.95 gallons + 1 full charge per 89 miles.
    Winter driving in a Prime really benefits from a temp monitor.
  11. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    1) Drive south. ;)
    2) I pre-condition the car/seats while on 240v in the garage and via phone app @ work and drive 100% EV both ways. Because of #1 above, I usually get better FE in our mild winters due to less HVAC usage to combat humidity and/or heat. (y)
  12. Amymonel
    Amymonel New Member
    San Francisco
    2015 Prius Plug-in
    In regards to the frozen windshield - I've had success with using a thick towel covering the main areas that i need visibility on. No defrosting or scrapping. Take the towel off and ready to go
  13. Rmay635703
    Rmay635703 Senior Member
    2,668
    1,687
    Somewhere in Wisconsin
    2013 Chevy Volt
    I dump a gallon of NG heated near boiling water rapidly across mine and squeegee it off.
    COST $0.06 instead of nearly a quarter, windshield stays clear quite long after, eliminated the need to condition or heat up anything.
  14. Mendel Leisk
    41,334
    I'd have the same concern though: might crack glass?
  15. Rmay635703
    2,668
    1,687
    2013 Chevy Volt
    Tempered auto safety glass, as long as you try to apply evenly across there isn’t any chance, unless of coarse you have a small crack or chip already in the window
  16. Tony1988
    Tony1988 Junior Member
    27
    Sweden
    2020 Prius PHV
