"Bumb" feeling front tires
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ketiana, Jan 9, 2018.
  1. ketiana
    ketiana New Member
    Today all of a sudden I felt two "bump" feeling from the front tires of my car when pressing the gas pedal after stopping at a red light. It kind of felt like I was running over something, even though I was not. This is the best way I can describe it. However now it's driving normally but I haven't taken it for a second drive after that happened. Should I get the tires checked?
  2. Mendel Leisk
    41,901
    Outside change there actually was something minor on the road, just you didn't notice it? Especially if it doesn't happen again, and the tires check out ok.
    You can have a pretty good look at the tires yourself: visually check what you can, and just run your hand along the tire face, for the rest. Then maybe roll the car forward or back a foot and repeat, to check the portion that was against the ground.
  3. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    It's likely you just got rock or two caught in the treads and driving a bit removed them. I often notice that my tires are imbalanced after coming off of dirt roads or road construction with loose bits of road, but it clears up in a minute or two of driving. However it's worth inspecting your tires to be sure.
    If the bumpy feeling comes back, it can be a sign that some of the threads in a tire are broken internally and a blowout will happen soon. It's probably not this, but worth checking to make sure your spare has full pressure and you everything you'd need to change a tire if needed.
  4. bisco
    52,390
    speed bump, no worries.
