To plug-in or not to plug-in...
Discussion in 'Prime Technical Discussion' started by SweetPriusBro, Jan 7, 2018.
  1. bisco
    52,390
    there are lots of advantages besides cost, but you do have to be willing to pay for them if your rates are high.
  2. fuzzy1
    10,603
    Does your utility offer some other rate plan choices for EV charging?
  3. rsl360
    rsl360 Junior Member
    17
    Cape Cod, Massachusetts
    In my area, (new england), it also seems to be pretty much a wash with gas vs electric. But wait until gas his $4.00/gallon, then see what you pay for one of these babies. And in any case, I'm still getting like three times the mileage of the car I was driving before.
    priuscatprimeguy, Mark57 and bisco like this.
  4. pyramidbuilder
    pyramidbuilder New Member
    Novato, CA
  5. pyramidbuilder
    Novato, CA
    I used $3.03 for gas, my last fill up. for EV, I used 26 mile on a charge and $.28 /KWh from my utility bill.I agree that electricity is expensive. However, the EV mode was really not the reason I bought the car. I can charge at work for free so I get 26 miles on a 17mi commute for free.
  6. rsl360
    17
    I mentioned earlier that the cost in my area was pretty much a wash, electric vs gas. But then I was thinking, my commute is only 7 miles. So I really need to find mileage cost for that route. While the car warms up fairly quickly, a good portion of that trip is with a car that is less the fully warmed up. I guess I'll do a few commutes in gas mode.
    eluo and Prodigyplace like this.
  7. SweetPriusBro
    SweetPriusBro Junior Member
    Vacaville, California
    I’m in the same boat. (And I’m also in Novato!)
  8. rsl360
    17
    So a quick follow up on this. Based on a singe experiment, it probably pays to use the electric mode for short trips. Here are the numbers for just gas mode. (well, hybrid mode):
    At 2 miles out, 30 mpg.
    At 4 miles out, 42 mpg.
    At 6 miles out, 46 mpg.
    At 8 miles out, 51 mpg.
    It was about 28f out when I left the house, and I drove the car in hybrid mode the whole time. The car was cold when I left. So it looks like there is something to be gained with electric mode for short trips, costwise. Also, I suppose it's better for the engine to not drive it for short distances, but really, when was the last time anyone ruined an engine? Sure, it's possible, but it's not common.
    Does the Prime have the coolant "thermos" or anything like that?
    eluo and E-GINO like this.
  9. bisco
    52,390
    no, they now warm the coolant by running it along the exhaust.
    that is a great point about short trips. my wife and i drive 4 miles each way almost everyday to go for a walk.
    we always take my pip in ev, rather than her hycam.
    was your test with no wall charge left in the battery?
  10. rsl360
    17
    The traction battery was fully charged.
  11. bisco
    52,390
    doesn't it use any in hv mode?
  12. Gaëtan Lafrance
    101
    77
    Montréal, Québec
    Technology
    Hi.
    Good question in California, here in Québec, the cost is 0,08$ per KWh. I don't have to ask me the questioon.; my cost is 0,50$ (CDN) to fill my battery.
    Désolé!
    Bonne année!
    Tideland Prius and bisco like this.
  13. rsl360
    17
    Use any of what's in the traction battery? I'm not sure. If it does, it's not much. HV mode tries to keep the battery at the same level. But I don wonder, if you depart in HV mode, with a full battery, perhaps it does use a bit, so as to make room to put some back. That would seem to make sense, but it would be hard to tell. Maybe I'll try it again tomorrow, but without a full battery.
  14. bisco
    52,390
    if you look at the battery icon mile estimate, you should be able to gauge how many miles it used by the time warm up is completed. any use would inflate your warm up mpg's above, making an even stronger case for using ev for short trips, even at high kWh cost.
  15. El Dobro
    El Dobro A Member
    7,093
    3,271
    It's pretty much the same in price between using gas and electricity around here, so I keep the car charged up as much as possible. For me, it's the ride more than anything else, I like driving electric. :D
    Old Bear, pyramidbuilder and bisco like this.
  16. bisco
    52,390
    cheap entertainment, especially compared to our monthly phone/internet/cable costs.
    jtv, benagi and El Dobro like this.
  17. El Dobro
    El Dobro A Member
    7,093
    3,271
    You got that right.
  18. Ed From Syracuse
    Ed From Syracuse Junior Member
    28
    35
    Syracuse
    Okay one thing. Whan I got my car in February 2017 I went 2 months before I needed to get gas. That's because I had the heat running and I was only getting 24 miles EV charge. When the weather got warmer. I started to get 34 miles EV. My drive to and from work a total of 28 miles. I charged at work when I could. And when I couldn't I still had at least five to six EV before I needed to charge. I went 7 months without putting gas in my car. Now I only spend .007 KWH. I haven't done the math but I do believe I am saving a lot of money on gas. Now that it's colder out I'm going about a month before I have to fill up. Unless my kilowatt-hours go extremely high I'm thinking about getting a electric vehicle.
    padroo and Andyprius1 like this.
  19. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I like the hell out of this post. All we have to do is look at China!
    priuscatprimeguy and padroo like this.
  20. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    I'm not sure that we class as "tree huggers" but why contribute to a problem if you don't have to? Kind of like walking five feet to a trash can rather than throwing your candy wrapper on the ground.
    Buying the Prime was Mrs. Bear's idea. I think she was motivated by the tax credits and the fact that she'd been sold on the idea of an electric vehicle after test-driving a Tesla. The cost per kWh here makes it pretty much a wash except for the fact that the Prime replaced a larger V-8 car and we will be saving about $1000 a year just because of the difference in mpge vs mpg.
    We make a lot of short trips around town and it's nice to be able to get into the car and go without worrying about warming up a gasoline engine or the effect of constant starting on a battery and starter system.
    When you think about pollution, you should also think about noise pollution. The quiet of the Prime is much appreciated both inside the cabin and out.
  21. fneil
    fneil Member
    71
    52
    Carrboro, NC
    And don't forget, the indicated mpg on the Prime is optimistic by 5-10% in my experience, when I check it via hand-calculation after fill-up, so cost per mile in gas mode is higher than it first appears.
