Charge Schedule Backwards??
Discussion in 'Prime Main Forum (2017-2022)' started by Gianni I, Jan 9, 2018.
  1. Gianni I
    Gianni I Member
    71
    40
    Long Island
    So I tried the charge schedule once with no success. I want to use it going forward and I think I may have captured a bug or I may have something set wrong. But it seems like my time is backwards. I want to set a departure time of 8am for each weekday. When I put that in, it seems to show up as 8pm. I think that’s the case because the red line that indicates the current time is right in the middle. I did this around 7pm tonight.
    I checked all clock settings and I believe everything is correct. Any ideas?
  2. Tideland Prius
    16,564
    Did you rotate the AM/PM wheel in addition to the hour and minute wheels when setting up your schedule?
  3. Gianni I
    Gianni I Member
    71
    40
    Long Island
    Yes I did. If you look at the picture it looks backward because the red line that shows current time is what looks like 7:45am when it’s actually 7:45pm
  4. Gianni I
    Gianni I Member
    71
    40
    Long Island
    Figured it out. When setting the time on the Top display I didn’t realize that had an Am PM setting. Changed that to the correct time and appear to be all set now. I set up my schedule for tomorrow morning to test out.
    priuscatprimeguy likes this.
  5. Tideland Prius
    16,564
    The clock in the MID, right? Ok good to know.
  6. Gianni I
    Gianni I Member
    71
    40
    Long Island
    Correct. Clock in MID has an AM/PM setting. Did realize. The dealer had that set when I got the car so never checked!
  7. Gianni I
    Gianni I Member
    71
    40
    Long Island
    Charge scheduled worked as it should btw after fixing.
    Mark57 likes this.
