Brakes creaking at a complete stop
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JLee, Dec 1, 2015.
  1. JLee
    JLee New Member
    Vancouver, BC
    I have a 2007 prius with just over 70,000 miles, and have begun seeing a few nagging small issues here any there. This car has not had any service done to the brakes as of yet.
    Recently, I've been noticing a creaking or clicking sound when I'm at a full stop. The creak or click happens as I depress the brake pedal further or release the brake pedal slightly (while still at a stop). The sound is like a beer can being slowly crumpled but with a higher pitch.
    With the age of this car, there is noise when turning and braking which other threads have pointed out. That noise seems unrelated to this ticking/clicking/creaking as this noise is indepedent of any movement in the car.
    Any insight is much appreciated.
    52,393
    welcome! could be the brake actuator, but these sounds are best diagnosed by a mechanic in person.
  3. JLee
    JLee New Member
    Vancouver, BC
    Thanks @bisco, was hoping for a miracle answer. I'm just hoping not to get conned out of paying a boatload for diagnostic work on my next maintenance.
    I'm familiar with the actuator noise, and it doesn't appear to be that. The pace is much slower, maybe 5-7 clicks across 1 second depressing the brake pedal fully.
  4. bisco
    52,393
    maybe the brake accumulator. is it the same as when you open the drivers door?
  5. JLee
    JLee New Member
    Vancouver, BC
    less of a buzzing.
    more like this:
    I guess that solves part of the question. most likely something to do with the pin or assembly?
  6. priusboston
    priusboston New Member
    boston, ma
    Any update on this? Was this a seized caliper? An ABS nightmare?
    SFO likes this.
