Has anybody replaced the undercar shield on a Gen III?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Wilf Brim, Jan 12, 2018.
  1. Wilf Brim
    Wilf Brim Junior Member
    Atlanta, GA
    Hi all:
    My just over 50,000 mile 2014 Prius 4 was 2 days past the 50k service and I heard first a whistling, then bumping from the right side of the vehicle, which went away. I heard a scraping at low speed later. It took me about a day to realize that the underbody cover had either fallen off or been ripped off on that side. Right now it's dangling and scraping at low speeds, probably gets pushed off the road at speed by wind.
    In other threads from other years I've seen dealerships will charge ~300 for the part and 100-200 to install. I found a part (can't post linky, sorry) for like 60 bucks plus shipping. I'm not that mechanically inclined, but can do simple stuff (oil changes and the like). I have jack and jack stand, so I can get under the vehicle.
    Has anybody here done this? How hard is it? I know that there are some bolts and some plastic rivets/clips. I'm guessing that at least some of the rivets will need to be replaced. Does anybody have a source for them? And where to get the tool to remove said rivets?
    Any help appreciated. I can post a pic, if desired, but there isn't much to see: just imagine the back right of the underbody panel hanging down and ripped up from where it's been dragging.
  2. FrankB
    FrankB Member
    117
    53
    I've done it with the $60 replacement, it's not hard. As you said, plastic rivets and some 10mm bolts. I got the rivets off of amazon and ebay. I use a screwdriver to remove the rivets but I've read a paint can opener is good as well.
    Rebound likes this.
  3. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    You don’t need a picture. Just the panel and the plastic “rivets.” You can reuse the existing rivets, but it’s better to buy new because they get beat up over time.
    There are two sizes of rivets used. Your dealer will have the info. Honestly, there are no gotchas at all. I’ve removed a few times for transmission oil and coolant changes. There are about three ten millimeter nuts and a bunch of plastic rivets. I like to go from rear of car to front.
    bisco and Tbkilb01 like this.
  4. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Who performed the 50K service? If it was the dealership then they can be held liable for not reinstalling the plastic undercover shield correctly.
  5. Mendel Leisk
    41,808
    There's a good chance you're missing some of the plastic push-in fasteners. There's two main kinds between the panel and the car, and a third kind I believe, between the "oil change flap" and adjacent plastic of the panel. There's also 6 10 mm (socket size) bolts. Mechanics using/abusing that oil change flap (it's a piss poor design, brittle plastic with a failure prone hinge) is one reason for failures I think, and/or they rush too much if they're removing/replacing the full panel, break or lose fasteners, just slam it back on
    I've had ours off, completely, maybe 18 times now, once for each oil change (every 6 months), and sundry other times, for various reasons. The key to longevity I think, is to maintain the fasteners.
    Removal or install, if you have all the fasteners, takes about 5 minutes. One thing: every time you remove the plastic fasteners, wash them in hot/soapy water, sluice out the grit. Then they will last.
    Anyway, raise the front of the car, see what you're dealing with, take a tally of fasteners, how many if any are missing. Go from there. I've attached a pdf with info on the parts numbers.
    Bay Stater likes this.
  6. Tande
    Tande Active Member
    547
    336
    Mich.
    This .....like most tools, makes the job a little more "Fun" ....
  7. Rebound
    3,996
    2,644
    Portland, OR
    I bought a pair of those. You still have to pry the fastener with a small screwdriver, enough for the pliers to grip, and then you can use those pliers to cleanly remove the fastener.
  8. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Mine is held on by zip ties....those plastic rivets are crap.
    gamma742 likes this.
