B Drive Question
Discussion in 'Prius c Main Forum' started by preeusluver, Jan 12, 2018.
  1. preeusluver
    preeusluver New Member
    bishop caifornia
    2015 Prius c
    I bought a 2015 C. I live in the Sierra Nevada mountains where going down steep grades is a routine driving experience.
    So as I start down a low grade in B Drive its a silent gear. As I continue downgrade as it steepens suddenly it sounds like I have turned on a blender as car speeds up and gear begins to work harder to keep car from speeding up. I mean this gear really starts to windout in a very loud high pitched whine. Now when I owned a pickup and down shifted at too high a speed one would get a similar sound.
    So my question is can one shift into this gear at any speed below 60 mph without doing damage. Is this whining gear a normal sound as it works to keep slowing the vehicle on steep grades? Is it doing and damage to use it when it goes into the blender sound? The manual does not elaborate on a speed range or max speed for shifting into B, or that it would make such a loud blender sound on steep grades. Appreciate any help understanding this gears use and noise potential.
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    B is safe at any speed, the computers do not let you exceed redline. (5200 RPM)
    B does not change the gearing, it just adds engine braking. It was counter-intuitive at first that the harder you braked, the louder the engine got.
    My Gen 2 had a very similar engine as the c, I described it as a baritone sewing machine.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Yes and yes. Perfectly normal.
    USE your brakes a little.
    B mode is intended to reduce the need for the conventional brakes, not to eliminate their use altogether.
  4. Mendel Leisk
    41,879
    I would reserve B for mountain descents. Would never use it for short hills, anything around town, or just for deceleration. Just leave it in D, use brake as needed; it'll charge the battery better, less wear-and-tear.
  5. ChapmanF
    18,517
    Do the Sierra Nevadas count? I think they're pointier than anything we've got in Indiana....
    -Chap
  6. Mendel Leisk
    41,879
    Yeah, sustained, relentless downgrades, wherever they may be, lol. But every time you encounter a downhill around town, fugedaboutit.
  7. padroo
    padroo Senior Member
    2,763
    2,252
    I use "B" sometimes in stop and go traffic to keep from tapping my brakes. It makes it more like driving a stick.
  8. preeusluver
    bishop caifornia
    2015 Prius c
    Slightly pointier by several thousand feet of uphill grade but whose counting!
  9. preeusluver
    bishop caifornia
    2015 Prius c
    Thanks for calming my anxious mind since I keep thinking the engine will just blow up as the whine reaches fever pitch. I cannot believe the manual does not discuss other than to say B is the braking gear...very lame!
    Heres a trivia...what gen is a 2015 priuc C? Still a preemie in the world of prius.
  10. Sam Spade
    2,036
    1,023
    2017 Prius c
    None of the above. It is it's own "gen".
  11. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Isn't it a "modified" Gen 2 Prius engine, though?
  12. ChapmanF
    18,517
    Yes, it's a 1NZ-FXE. Why not call it a modified Gen 1 engine? Eh?
    By the same token, the c was born the same time as the mid-Gen 3 refresh, and is most similar to a Gen 3 in the various included tech.
    -Chap
    ztanos likes this.
  13. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    That's fair. It really is a hybrid of Gen 2 and Gen 3. :D See what I did there? A hybrid. Ha ha ha ha. I'll see myself out.
  14. preeusluver
    bishop caifornia
    2015 Prius c
    So to summarize its too special to have a GEN # and so we give it a 1NZ-FXE! I am just a simple son of a camel driver...so I will also call it based on this fascinating discussion a modified gen 1- 3 hybrid gen 2-3! Meanwhile I'll just cruise down the Sierra grades in B drive sounding like i am making a frappucino at Starbucks. Thanks all:LOL:
    ztanos likes this.
  15. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    As soon as there is a gen 2 Prius c, yours will be a gen1 c.
