My Prius honks at me
Discussion in 'Gen 2 Prius Main Forum' started by larry_doliver, Jul 21, 2006.
  1. larry_doliver
    larry_doliver New Member
    When the car (2006 Prius #7, ~400 miles) is locked and I approach the drivers side door with the smart key, it honks (on and off, like an alarm) at me until I a) press the unlock button on the remote or b ) touch the door handle to unlock via smart key.
    Anyone else seen this? Am I doing something with the Smart Key sysem wrong?
  2. richard schumacher
    7,664
    1,045
    United States
    Every time? How do you lock it?
    Simple possibilities: car was not shut OFF when you left it, or door or rear hatch were not completely closed; but in these cases it will also honk at you when you try to lock it and walk away. Other simple possibility: you accidentally push the alarm button on the fob when walking up to the car.
  3. unruhly
    unruhly New Member
    205
    It should not do this.
    Just to clarify: It is the horn honking? As in "Panic" button being pushed?
    There have been a couple of posts about the panic button getting pushed while in a pocket or purse and this would get cancelled by the steps you mentioned.
    I guess it's possible that your panic button on the fob is extremely sensitive or even stuck. Try the other fob while your regular fob is well out of range and see if you have the same results.
  4. marjam
    marjam Member
    220
    Silver Spring, MD
    I was one of the posters who has a problem with the Panic button on the fob being pressed when it was in my pants pocket or in my hand. It still happens and it scares me and drives me nuts. When the car goes in for the Steering recall I will ask them to disable the panic button with the scan tool. It can be done but I want to see if this also disables the horn if someone tries to break in. I bet that the "sensitive" panic button on the fob is the cause of this poster's problem also.
  5. larry_doliver
    I don't think its a panic thing, or it would start when I'm within remote-button-pushing range. It only starts honking when I'm 2 feet from the drivers door (not passenger door or trunk), and the honking stops as soon as I touch the door handle to unlock. Doesn't matter if I lock via remote or the lock button on the door.
    I'll see what toyota service has to say...
