Engine runs when <25° even when in EV mode. Normal?
Discussion in 'Prime Main Forum (2017-2022)' started by dmigel, Jan 17, 2018.
  1. dmigel
    dmigel Junior Member
    St. Louis
    This is likely not an issue but just looking for confirmation that it’s normal for the gasoline engine to sporadically kick in when it’s really cold outside (<25° F) even when its in EV mode. I haven’t figured out exactly what buttons are pressed as far as heated seats, defrost, heat etc to determine correlation. But I’m just looking for someone to tell me it’s normal for this in certaiN Circumstances.
    I was led to believe that in EV mode it would only use battery power no matter what until depleted.
  2. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    95
    Indiana and Nevada
    normal...the colder it gets the more probable the gasoline engine will run, even though you are solely in EV...Additionally, when turning on the defrosters the engine will turn on...so your observation is normal...
    dmigel likes this.
  3. dmigel
    St. Louis
    Thanks. Just wanted to make sure I didn’t need to get to the dealer.
    Found this forum to be super valuable.
  4. DavidA
    2,348
    1,823
    Chicago western burbs
    With no accessories on (cruise control, heated seats, heated steering wheel, either of the window defrosters, or cabin heat) the car is supposed to start in EV mode above 14 degrees. Here's the kicker though...
    Let's say that the air temp on the MID says it is 25 degrees outside, but overnight it was much colder; 5 degrees? It will take many many hours for the battery temp sensor to warm up to match the daytime temperatures. I've had my Prime gas engine ("ICE") start right away in the upper 20's under similar conditions. I've also had the car start in EV mode at only 15 degrees, and stay in EV. The car does what it thinks it needs to do.
    Trollbait likes this.
