120k mile service - potential DIY questions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by letsgobobby, Jan 21, 2018.
  1. letsgobobby
    letsgobobby Junior Member
    32
    My 2012 Prius has 121,000 miles and I’m debating if this is DIY territory.
    I understand it needs:
    - oil change
    - air and cabin filters
    - spark plugs
    - rotate tires
    - check fluid levels/lube
    In addition, we’ve never replaced the battery on this vehicle and I think it should be done. I’ve previously posted about that and just never got around to doint it.
    The radiator coolant was done at 100k miles by the stealership.
    I also understand the inverter coolant is due at 150,000 miles
    Is the 120k mile service doable at home? I can certainly do the air filters. I’ve changed oil on another vehicle but not the Prius - do I need jack stands?
    I have a spark plug socket wrench and understand there’s some work to get this done but it’s not difficult. I haven’t relaced spark plugs on a vehicle in 30 years.
    Finally, when it comes to do the inverter coolant in 30k miles, is that something I should do or take to the stealership? I didn’t do the radiator coolant because it hit at a very busy time, but I can plan ahead for the inverter coolant and it doesn’t look difficult.
    Up until this point we’ve had the dealer do all the work but since I recently did a difficult oil change on a truck I’m feeling empowered... like I can do this... plus I now have a funnel, an oil pan, and a filter wrench (though it may not fit the Prius filter).
    Other than OEM, what brand air and oil filters, oil, inverter coolant fluid, spark plugs are recommended?
  2. JC91006
    JC91006 Senior Member
    16,928
    8,637
    These are very minor things to change out, tackle them 1 at time and have some fun.
    You'll need a special oil filter tool to remove the oil filter. And yes you'll need jacks or a ramp to give you more room.
    I use oem parts mostly, but air filters and coolant, I've used after market brands with no issues
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    JC91006 likes this.
  4. cyberpriusII
    1,157
    1,850
    Hyampom
    You don't need a special filter wrench. You will probably need a small size wrench that fits the Prius filter. $3-$4. I actually can take the filter off by hand.
    Probably need some sort of safe lifting -- such as jackstands. I have always been able to do without. Most dealerships sell the filters for a reasonable price, about the only thing they sell for a reasonable price.
    Cabin filters have been discussed to death on this site, considering what a minor part of the car they are. You can spend upwards of $25 or $30 or more at the dealer. I spend around $3-$4 on Ebay or Rock Auto for the TYC brand of Cabin Filter. Engine Air Filter is important. The one aftermarket brand I tried (Purolator) did not fit well. I stick to the Toyota.
    If you are changing out the Engine air filter, also clean out the snorkel as long as you are at it.
    Opps, just realized I accidentially posted on the GEN 3 forums. Sorry my comments apply to a GEN 2.
    A little bleary-eyed this morning.
    #4 cyberpriusII, Jan 21, 2018
  5. letsgobobby
    32
    It looks like I’d need to get into a jack and jack stands to do the oil and the inverter coolant. Those don’t look difficult, though. Do I need to jack up front and back equally so the vehicle is level for these procedures? In other words do I need two sets of jacks and stands? I would then have them for my RAV, as well, so they would pay off easily.
    Definitely going to pass on the spark plugs! While not difficult, it looks tedious and time consuming.
    Obviously I will do my own air/cabin filters.
    Meanwhile those videos gave me the idea to clean the throttle body sensor, since I need to do that on my RAV as well (and the MAF on the RAV, is that something I should/can easily do on the Prius? That wasn’t in the Nutz videos).
  6. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    If you can get the Gen3 oil filter housing off by hand, you’d put a lot of us to shame ;).
    But you beat me to it(y).
    xliderider and Mendel Leisk like this.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    All can be done at home.
    Add 'change ATF fluid' to the list also if you plan to drive the prius forever and 'relube brake caliper pins' whic requires you to disconnect 12v battery.
    To get some of the things off your list crossed the fastest in specific order: Find a leveled spot, disconnect 12v battery negative clamp. loosen all lug nuts, use chocks at designated tires, lift & jack stand entire car. Remove plastic under carriage. Drain ATF, remove all tires to relube brake calipers and rotate tires then only hand tighten nuts, refill ATF, remove rear jack stands only, drain engine oil, switch filter, drain screw goes back, put plastic under carriage back, remove front jack stands and refill engine oil. Pump your brakes until it's tight to push down pedal, reconnect battery. Start up prius, admire the dash x-mas lights because other dash lights appear like car is broken. After ICE turns off, turn car off and back on with no xmas lights. If ICE didn't come on, just turn car off and back on. (ATF & oil change + caliper relube + tire rotation + removing leafs and rocks stuck between car underbody and plastic shield done)
    As for the 12v battery, check the date on it. If it's not older than 5 years and car is garaged most of the time just drive it until you notice little electronic glitches first before replacing it. Just deferring a bill, but if it helps you sleep better at night to change it the next chance you get, go for it.
    Other brands I used are K&N filter, Mobile 1 advance fuel eco 0-20w, 3m anti seize for calipers. Hope others chime in on alternative brand parts.
    m3pare, pidginbil and Raytheeagle like this.
  8. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    No need for 2 sets of stands, but you never know:whistle:.
    I made my own out of spare wood I had “just lying around” as underneath the wheels elevators for everything other than Work requiring the wheels to be removed;).
    The capacity of the transaxle is 4 quarts (I filled ours to 126 ounces before it came out so 2 extra ounces won’t hurt). No need to level if you don’t have the space for storage of equipment.
    As for cleaning the Maf, it is easy and should be just as easy on a RAV4 as it is on a Prius:).
    Hope that helps(y).
  9. frodoz737
    frodoz737 Top Wrench
    4,790
    2,553
    33
    Consider doing a brake flush while doing your brake pin lube and general cleaning/inspection. NutzAboutBolts also has a good video about doing that. Toyota uses DOT 3 on the GEN III's and like the Toyota labeled WS ATF, this is also NOT a lifetime fluid.
  10. padroo
    padroo Senior Member
    2,763
    2,253
    Automotive ramps are a good choice for oil changes and other maintenance items under the front of the car instead of jacking the car and putting jack stands under it. You will have to have the car back on the ground level to check the final fluid levels.
    You don't need very high ramps for oil changes and get them longer rather than short so your bumper doesn't hit them.
    http://www.youtube.com/watch?v=d1-Dp9w0x78
  11. letsgobobby
    32
    Good idea, I guess my question is if only the front is jacked up or ramped up, will the oil and coolant fluid drain properly with the car on an incline?
    Sorry guys - I’m going to pass on flushing brake fluids, etc. Out of my comfort zone!
  12. Mendel Leisk
    42,218
    I'll try to address just your oil change questions. Considering the level of your questions, I'd suggest to just take that on first, see how it goes.
    For the oil filter on our 2010 I use a Honda socket, it's the same flute size/number, works fine. It's their standard oil filter size: 14-flute, with inside face-to-face dimension of around 64.5 mm. Mine is ancient, the parts number out of date, but google it and you'll find up-to-date offerings, on Amazon or wherever. It's heavy gauge stamped steel, very durable.
    There's various Toyota specific sockets for sale, with special extra slots that cup around ribs on the sides of the oil filter housing. I'm skeptical as to how necessary these extra slots are, have never had a problem. Some of them are of suspect quality, thin cast aluminum, or thin stamped steel. I do not know, do know that the Honda filter has worked for me, for decades.
    With the oil filter socket, it's worthwhile to use it with a skookum, long-handled ratcheting wrench, and an extension or two are handy. The torque value for the oil filter housing is 18 foot/pounds, for that a 3/8" micrometer style torque wrench would be good.
    There's a clip beside the oil filter housing, much discussed, noted in the Repair Manual, that does squat. You can basically ignore it, it won't impede removal or install of the housing. The Repair Manual also goes into a lot of detail about unscrewing the housing to a particular position, then tipping to drain oil before unscrewing further. This was written by the same guys that dreamed up the clip I think, pretty much pointless.
    When removing the drain bolt, the washer, which has some sorta coating, tends to glue itself on to the oil pan. I'd suggest to loosen the drain bolt just a turn or two, then tap the washer loose with a screw driver and hammer, then carry on removing the bolt, together with the washer. It's good practice to always replace with new, maybe overkill, but what the heck. Torque on the drain bolt is 27 ft/lb.
    For oil change I raise the front with a floor jack, at the front/central jacking point (consult your Owner's Manual, though it's pretty obvious when you look under), then settle the car onto safety stands. I do not use the front scissor jack locations for the safety stands; they're ok for the supplied scissor jack, but poorly suited, unstable, and too weak, for a typical safety stand cradle. The points I put my safety stands are just inboard a bit, at the leading end of longitudinal body rails running along the underside. They're very solid, and stands are very stable there. If you're going to be using safety stands and are interested, I can post pics.
    I remove the full engine underpanel for each oil change (done maybe 15 now?), and wash all the plastic fasteners out before reinstalling, to avoid them getting jammed with grit. There's maybe 10 plastic push-in fasteners, in a couple sizes (see attached TSB). Most are smaller/black ones, and two at the rear are larger, with grey heads. It's worthwile to mark those and their location, with some sort of white sharpy pen. There's also six 10 mm (socket size) bolts to remove. I start at the back when removing fasteners, work to the front, then finally when all fasteners are out wiggle the panel out from under the next plastic piece ahead of it. Install is the reverse. Note: you can just remove a few fasteners bend back the flap at the oil pan, but that's how the dang thing gets broken. If you've have professional oil changes in past, that's likely what's been done, and the flap may be partially broken already. And/or the whole panel may be missing one or more fasteners.
    The simplest way to get the correct oil filter, drain bolt washer, is to just buy through a dealership parts department. You'll need also 4.5 US quarts (4.2 liters) of 0W20 oil (they can sell you oil too, my pref is Toyota oil).
    I've attached the oil change instruction from the Repair Manual, and a Toyota Bulletin which shows the fasteners. You don't really need the latter, just be careful when removing the panel, be organized.
    Addendum: think this is the current part number for the Honda oil filter socket:
    07AAA-PLCA100
    And a Honda dealership link:
    07AAA-PLCA100 | Honda Oil Filter Wrench - Bernardi Parts
    Mostly just for confirmation; it's available on amazon as well. Bernardi's price is good though.
    #12 Mendel Leisk, Jan 21, 2018
  13. CR94
    CR94 Senior Member
    2,810
    1,234
    Northwestern S.C.
    You don't need two sets of ramps to get the car level for oil changes. I do it with the car headed downhill, with only the front on ramps, so it ends up level. (That tactic might be hazardous with jacks and jack stands, tho .)
    If the drain washer sticks to the oil pan, that's good. It means you don't have to handle it, and can reuse it without risk of leaking.
    padroo likes this.
  14. Mendel Leisk
    42,218
    Car doesn't need to be level for oil change though.
  15. letsgobobby
    32
    Got it, thank you
  16. letsgobobby
    32
    Dealer only wants $220 for spark plugs, which is about $80 better than I had thought. I went ahead and had them do it.
    They keep insisting the inverter coolant was due at 100,000 miles even though my manual clearly states otherwise. 100k is for the engine coolant, 150k is for the inverter coolant. I’ll do that myself in 30k more miles. I’ll get some ramps and start changing the oil and filter myself, as well as the engine coolant every 50k.
    What’s the current thinking on the transmission fluid? Has never been changed, I know Toyota says lifetime but everyone here says to do it. Should I do it now? How often thereafter?
  17. padroo
    2,763
    2,253
    The main thing on the transmission fluid is to just get it changed and after you see how dark it is compared to the new stuff you can decide what is right. I changed mine at 60,000 miles on my Gen 2 and it was a little darker than the new fluid. Good luck.
  18. Mendel Leisk
    42,218
    I wouldn't say it clearly states it. It first says to change both, but attaches a little postscript symbol, which when you track it down, on the next page, it says to just change the engine coolant, and so on.
    Page 50:
    Page 51:
    That's kinda the opposite of clear, maybe confusing Toyota Service Departments?
    Now for my 2010 Prius, my Canadian schedule says to change both, at 160K km's (or 10 years, whichever comes first), with no tricky postscript. This is from the 2014 schedule, but it's the same, and I prefer the format of this one:
    This schedule covers all Canadian Toyota cars, not just Prius. Then, to keep things interesting, there's this on the side of my Prius' inverter coolant reservoir:
    #18 Mendel Leisk, Jan 22, 2018
  19. letsgobobby
    32
    Well, I thought the postscript was pretty clear. All you have to do is read it. :)
    It’s reassuring to see that sticker say 150k miles, since your manual suggests 100k miles. Maybe I’ll split the difference and just do it at 125k. No biggie.
    But then how often? 50k each for the engine and inverter coolants?
    And are the spark plugs going to be 120k going forward (ie, next at 240k)?
  20. Mendel Leisk
    42,218
    You mean for subsequent changes, of both? See second image in my post above: 50K miles or 60 months.
    BTW, for me it's gonna be 10 years, for both (Canadian schedule), we're very low km's, time governs by a long shot. @NutzAboutBolts has the definitive videos on changing the fluid in both circuits.
    Might also be a good time to inspect the coolant pumps.
