At risk of ridicule -- how to get paper out?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by EastR, Mar 20, 2017.
  1. EastR
    EastR Junior Member
    85
    Miami, FL
    2016 Prius v wagon
    I store papers in the compartment beneath the CD changer on my 2006. Today one of the papers fell in the opening between the top of the compartment (see arrow). Any idea how to get it out without taking apart the dash?
  2. ChapmanF
    18,587
    Ok, I've never owned a Gen 2, or the Gen 2 repair manual, but it sure looks like that compartment might come out much the same way the same compartment on a Gen 1 does. I made a video that shows that for a Gen 1. It's the first thing out in the video, no need to watch the rest.
    Look around for similar little clips on the bottom and see if it will pop out the same way:
    Just don't get too brute-forcey if it doesn't come out easily that way, 'cause there's a perfectly good chance it isn't exactly like Gen 1 and there's some other step. There's always the repair manual in that case.
    -Chap
  3. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    You have to first remove the panel under the steering column, then the two vent assemblies each side of the radio, then the MFD, then you'll have access to the radio. Search for dashboard removal, you'll find instructions and probably video.
  4. ChapmanF
    18,587
    Are you sure all that has to come out before the compartment the papers slipped over?
  5. Mendel Leisk
    41,947
    BTW: is this the fabled hidden compartment?
  6. andrewclaus
    993
    326
    Golden, CO
    Someone may know a way to attack it from below the dash, but I've never needed to.
    Except for the MFD which has four 12mm machine screws, and a phillips or two on the lower panel, it's all snap-on and takes minutes, at least the second time. I did a bit of radio work last year and got pretty fast at it.
  7. EastR
    EastR Junior Member
    85
    Miami, FL
    2016 Prius v wagon
    Unfortunately the lost paper from a few months ago seems to have found a way into the vents/blowers. A loud clicking noise (see video below) now comes -only- when I turn the A/C vent fan on recirculate (not on outside air). It is intermittent but loud. I took off the dash panel today and still can't diagnose the location of the problem. Any help would be much appreciated!
  8. bisco
    52,417
    have you looked under the cabin filter?
  9. JC91006
    JC91006 Senior Member
    16,834
    8,604
    Put your hands in the fan (while the car is off) and see if you can get the paper. The fan is the big giant hole under the cabin air filter
  10. Mendel Leisk
    41,947
    Somehow it doesn't sound like paper, though I could be wrong...
  11. bisco
    52,417
    baseball card?
  12. EastR
    EastR Junior Member
    85
    Miami, FL
    2016 Prius v wagon
    I will try to look under the fan. Somehow it must have been pulled in from the small compartment below the MFD. It’s a piece of paper about 5”x7”. Could also be something else but the noise has gotten more frequent over the past month.
  13. bisco
    52,417
    if it is not in the fan area, you might have to dismantle the dash.
  14. EastR
    EastR Junior Member
    85
    Miami, FL
    2016 Prius v wagon
    No luck on reaching inside the fan under the cabin air filter. Where the video is pointed toward the white plastic is where the vibration feels the strongest.
  15. bisco
    52,417
    it's probably caught somewhere, and flapping in the breeze.
  16. EastR
    EastR Junior Member
    85
    Miami, FL
    2016 Prius v wagon
    The strange part is it only happens when air is recirculating but not when set to pull air in from outside.
  17. bisco
    52,417
    that is odd, it must be caught in the intake for the cabin air.
  18. Tideland Prius
    16,623
    You should head over to the audio section and look for people replacing the head units - that way you can see a DIY on how to remove the panels.
    I looked into my archives and this is the closest one I can find - see attached PDF.
    The passenger side can be removed mostly without tools like a screwdriver.
    Raytheeagle likes this.
