MPH and HUD
Discussion in 'Prime Main Forum (2017-2022)' started by LadyPrius, Jan 26, 2018.
  1. LadyPrius
    LadyPrius Junior Member
    29
    On nav system someone tell me what the HUD is and how can I get the speed limit on the screen to show all the time? or is there no setting for it.
    thanks
    Still Learning.:confused:
    #1 LadyPrius, Jan 26, 2018
  2. Diemaster
    Diemaster Active Member
    295
    262
    so. cal
    only the advanced has the hud. the only thing i got it to show was the EV range remaining to 0. i'd like it to show more too.
  3. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Use the trip meters. There is also a trip meter for "since start up". On my advanced, the trip button is on the left part of the steering wheel, and it toggles trough all the trip meters.
  4. LadyPrius
    29
    Thank u so since I do not have advance the hud does not apply.
    MJP - not sure if your response pertains to the mpg? Thanks.
  5. LadyPrius
    29
    Oooooooops, meant speed limit not mpg.
  6. LadyPrius
    29
    Where can I set this on nav.?
    Thanks
  7. Prodigyplace
    12,654
    11,825
    Central Virginia
    The navigation gets the speed limit from the map data. You cannot set it.
    LadyPrius likes this.
  8. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    There's one setting of the Multi-Function-Display that shows compass bearing and speed limit, but then you lose seeing the hybrid driving indicator. Use the '<' and '>' buttons of the right-side steering wheel controls to scroll through the displays.
  9. LadyPrius
    29
  10. LadyPrius
    29
    :sneaky: nav. thanks
  11. Prodigyplace
    12,654
    11,825
    Central Virginia
    You set mpg by proper use of the accelerator & brake, BTW. :LOL:
    benagi likes this.
  12. LadyPrius
    29
