Did they get rid of the fuel "bladder" in the C?
Discussion in 'Prius c Main Forum' started by Larry Greenwald, Jun 22, 2013.
  1. Larry Greenwald
    Larry Greenwald Junior Member
    67
    2018 Prius
    I should have asked this before, but I remember a lot of complaints or so about the fuel bladder in the tank for the Gen II. Did they get rid of it in the C (and also the Gen III of the regular Prius)? If so, what has replaced it?
  2. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Neither the Gen III nor c have the bladder. It's just a normal solid tank.
    minkus likes this.
  3. Castanea
    Castanea Member
    39
    27
    Iowa
    As usual, I find my answers here at PriusChat! Like the OP back in 2013, I'd read about the fuel bladder, especially in the excellent "What every newb should know" sticky thread in the Newbies forum, so I've been careful at the gas pump in the couple of months I've been driving this car. Also, I was remembering the owner's manual saying "don't top up the tank." I re-read that part of the manual this morning, and noted that its stated reason is to prevent overfill and spillage. I am very glad to know that there is no bladder to worry about.
  4. Prodigyplace
    12,678
    11,830
    Central Virginia
    The reason not to overfill is it can damage the vapor recovery part of the pollution control system.
    That is true for most any car these days.
    joelg1988 and padroo like this.
  5. farmecologist
    farmecologist Senior Member
    1,960
    1,799
    Southern MN
    I'm being dumb but what was the reasoning for the 'bladder' in the Gen2? I never looked into it.
  6. Prodigyplace
    12,678
    11,830
    Central Virginia
    @Tideland Prius do you remember why?
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    By having the gas tank stay the size of the gas in the tank, there was no room for fumes and so vapor recovery was excellent.
    Fuel did not slosh as it was always the size of the tank.
    The bladder was excellent except the user interface:
    Slow filling, involving bizarre rituals. (I still open my gas cap before paying, and it is 5 years since I had a Gen 2)
    Different sized tank by outside temperature made predicting when to refill involve prayer.
    The gas gauge had no more idea how much gas was left than you did. Range anxiety.
  8. Tideland Prius
    16,615
    The bladder was a one-time thing on the Gen 2.
    All Prii after that do not have the bladder. They use a vapour canister or a pressurized fuel tank.
    Like Jimbo said, it was for emissions. The Prius' primary goal was to reduce emissions and fuel economy was a side benefit. The rubber bladder in the Gen 2 reduced evaporative emissions to help it earn the AT-PZEV rating (Advanced Technology-Partial Zero Emissions Vehicle) that is one step up from SULEV (Super Ultra Low Emissions Vehicle).
    Evaporative emissions is the gasoline vapours that form in the gas tank when you have less than a full tank. (On older cars, sometimes you hear a whoosh or a hiss when you open the gas cap to refuel - that's gasoline vapours escaping)
