EGR cleaning increases MPG?
Discussion in 'Gen 3 Prius Fuel Economy' started by Jason Zarraga, Jan 30, 2018.
  1. Jason Zarraga
    Jason Zarraga Junior Member
    Thanks to @NutzAboutBolts , I've successfully cleaned up my EGR module. Thank you man, you rock!
    I've noticed an improvement of mileage at moderate speeds. Is this common or is this just wishful thinking on my part? If so, why? I don't understand why recirculating burned gasses into the combustion chamber and reburning it improves MPG.
    NutzAboutBolts and Raytheeagle like this.
  2. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    Wait until you fill up your next tank(s) and see how that compares to your previous mpg.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    How many miles on your Prius?
    How clogged was the cooler?
    I swapped out our EGR cooler about 50 k miles ago and the mpg increased slightly :).
    But I also slowed down a bit which helps mpg more;).
    Cleaning the cooler goes further with reducing other failures than the mog improvement. Hope that helps (y).
    m.wynn likes this.
  4. Jason Zarraga
    I just broke 150k miles and I've always driven like a grandma haha
    What's the collet you're referring to?
    Raytheeagle likes this.
  5. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    The egr cooler is just upstream of the egr valve. If you haven’t cleaned that at 150 k miles, that will need to be addressed.
    m.wynn and SFO like this.
  6. Jason Zarraga
    Is the cooler where the radiator lines go into? I cleaned that as well as the valve. Are we talking about the same thing, the block with fins inside?
  7. mjoo
    mjoo Senior Member
    1,159
    1,329
    Michigan
    EGR does a few things for the engine. It lowers combustion temperatures thus improving the knock limit and allows advanced timing. Heating more air with the same amount of fuel improves the work done on the piston. Toyota says it allows for faster ignition (see "tumble ratio") which means more efficient combustion. And lastly, EGR lowers throttle losses at part throttle - this is what you're noticing.
    Toyota Global Site | Engine (Atkinson-cycle)[HV]
    Toyota's Next-Gen Prius to Possess Engine with 40% Thermal Efficiency - World Industrial Reporter
    Pixel XL ?
    Kevin_Denver and m.wynn like this.
  8. mjoo
    mjoo Senior Member
    1,159
    1,329
    Michigan
    padroo likes this.
  9. padroo
    padroo Senior Member
    2,763
    2,252
    EGR systems cause a lot of driveability issues with all cars.
