DRCC Cruise Control Sensors Locations?
Discussion in 'Prime Main Forum (2017-2022)' started by stevepea, Jan 29, 2018.
  1. stevepea
    stevepea Senior Member
    535
    581
    Quick question:
    As someone who never washes the outside of his car, I know it's important to at least keep where the sensors are located for the DRCC, clean. Does anyone know exactly where they're all located, so I can occasionally check to make sure they're clean?
    #1 stevepea, Jan 29, 2018
  2. Prodigyplace
    12,532
    11,755
    Central Virginia
    The DRCC radar sensor is located behind the Toyota emblem on the front of the car.
  3. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    I've never had a problem with the DRCC no matter how dirty my car got. I'm on my second Prius that had DRCC. The other sensors, if you have them, are the blind spot monitoring, cross traffic alert, and parking.
    Prodigyplace likes this.
  4. RRxing
    RRxing Senior Member
    2,545
    1,821
    NEPA
    What (s)he said...
  5. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I thought the new system also uses a camera behind the rear view mirror. It uses pattern recognition to avoid pedestrians and it confirms that the radar isn't just seeing a bridge expansion joint, which can trip the earlier system (such as on Pearl S). You can see it through the windshield. So keeping the top of the windshield clean might help.
  6. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I had the DRCC drop out on a trip in nasty weather last winter due to the dirt on the Toyota emblem. My wife had her's drop out in a Subaru due to a dirty windshield (Subaru had a 3D vision video camera and no radar). So keeping the sensors path forward clean is required.
    JeffD
    bwilson4web likes this.
  7. Prodigyplace
    12,532
    11,755
    Central Virginia
    I think the camera is mainly for pedestrian avoidance but it can't hurt to keep that part of the windshield clean too.
  8. bwilson4web
    16,195
    And lane keep assist alerts.
  9. Prodigyplace
    12,532
    11,755
    Central Virginia
    I forgot about that because I keep it turned off.
  10. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Turned mine off too.
  11. stevepea
    535
    581
    Thanks everyone, good to know. I'll try to keep those areas clean
