car shut down
Discussion in 'Newbie Forum' started by Lindsay Griego, Jan 31, 2018.
  1. Lindsay Griego
    Lindsay Griego New Member
    wilkes-barre
    HI...we just bought a 2009 prius less then a month ago. after driving it for less then 1000 miles.....the engine started shaking and all the idiots came on, including the death triangle, and the whole car stopped driving totally. It is now at the garage...and the code it gave was a crank sensor...so they replaced it and it still is giving that code. please help
    RCO likes this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Hello and welcome to Prius Chat. Sorry to learn of you troubles, though I can't answer them myself, the American chapter of Prius Chat will be offering advice pretty soon. Good luck!
    Lindsay Griego likes this.
  3. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Welcome to Prius Chat. Sorry to hear of your problems. We used to live in the Pocono's. What garage did you take your Prius too? I bought a car from Motorworld but didn't use their service dept. much but when I did they seemed good to deal with. Halterman's in E. Stroudsburg has a very good service dept.
  4. bisco
    52,103
    congrats and welcome!
    they might have to clear the code, or you can try disconnecting the 12v negative for a few minutes.
    how many miles on her?
  5. Lindsay Griego
    wilkes-barre
  6. Lindsay Griego
    wilkes-barre
    we had it at steve shannon..but they couldnt figure out the problem. so we are now taking it to motorworld in wilkes barre.
    RCO likes this.
  7. Lindsay Griego
    wilkes-barre
    is it possible its the transmission?
  8. Prodigyplace
    12,596
    11,792
    Central Virginia
    Welcome.
    I hope not. That is low mileage for those issues, IMHO.
  9. Lindsay Griego
    wilkes-barre
  10. paprius4030
    2,077
    296
    York,Pa.
    Let us know how you make out with them at Motorworld.
  11. Lindsay Griego
    wilkes-barre
    I should also add we had the crank sensor replaced and that code is still coming up?
  12. bisco
    52,103
    they might have to clear the code, or you could try disconnecting the 12v negative for a few minutes.
    RCO likes this.
  13. Lindsay Griego
    wilkes-barre
    well..we just heard it was the transmission. thankfully with my father in laws discount....it is a little over 2000.00...so that could be worse. what are the chances that the transmission is the first thing to fail and everything else could start failing?
  14. bisco
    52,103
    at 120k, anything can happen, but your usually good until 150-200k.
    Prodigyplace likes this.
