2007 prius with code P0AA6
Discussion in 'Gen 2 Prius Main Forum' started by Kimberly Lands, Feb 4, 2018.
  1. Kimberly Lands
    Kimberly Lands New Member
    Bull head City, AZ
    Four Touring
    Okay I am new to the Prius Chat. I need some serious help. This is a long ordeal I have with this prius. Anyways I have a 2007 Prius it has about 102,0000 miles on it. It has always ran great for me. I put new tires on it. Then a month later I'm driving to the store the car is driving perfectly I stop at a stop sign and all of a sudden the triangle of death is on along with the break light, the vcs, abs, and hybird warning light I drive the car home park it turn the car off and later that day went out and started the car it was stuck in nutural. after I did a diagnosis on the car from the screen and seen that the 12v battery was low, these codes came up 01-DB-190-10-F and 01-DB-110-6F-5 and 01-D5-190-27-5. I barrowed a friends code redear anf the following codes came up P0AA6 snd P0300. I replaced the 12v battery all the warning lights went off . The car was driving just fine for almost 24 hours then it happened the triangle of death, the the hybird warning light, the abs, the break, and the check engine light took the car immediately home again shut it off and it's stuck in natural again. Used the obd2 code reader again and the the code P0AA6 and it said battery connection circuit stuck closed. If anyone can help me figure out what is going on with my car I would appreciate it. I'm trying to fix it without having to go to the dealership.
  2. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    999
    The P0AA6 code denotes a high voltage leak. Normally the high voltage system is isolated from the rest of the car. When such a leak is detected the car will run fine until it is shut off. Then it will not start again. Disconnecting your 12 volt battery cleared the code and allowed the car to run again.
    The likely sources for the leak are the hybrid battery, transmission, and air conditioner compressor.
    Steve at Phoenix Hybrid Batteries could get your car running again. I'm sure that Bull Head City is too far away for him to come to you, so you would have to go to Phoenix.
    brad
    m.wynn, fotomoto, SFO and 1 other person like this.
  3. JC91006
    JC91006 Senior Member
    16,482
    8,400
    If the leak is in the battery, Steve can put in a brand new Toyota battery for $2000, including tax. With your low mileage, your car should go another few years without many issues.
  4. kenoarto
    kenoarto Senior Member
    396
    Chicago, IL
    $2000 to install a battery? It's a 45 minute job for an experienced pro...
  5. JC91006
    16,482
    8,400
    This includes the new battery
    m.wynn likes this.
  6. kenoarto
    396
    Chicago, IL
    Compared to last year it is great price. New Toyota batteries are down to $1625 this year. Even with tax, that's about $200/hour.
  7. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    I doubt even a seasoned installer could install a Toyota New battery in 45 min. It is not just a simple swap like a Dorman.
    $2000 is a decent price for a supply and install of a Toyota New.
    strawbrad and kenoarto like this.
  8. JC91006
    16,482
    8,400
    You have to drive to the dealer for a new battery, prep the core return, install the electronics onto the new battery, then install in the car. That's already more than 2 hours, you still have to drive to the customer to install
    The $2000 price is not a big profit maker, maybe $50 an hour. The benefit is recycling your bad modules back to the dealer whenever you buy a new one.
    m.wynn, strawbrad and Raytheeagle like this.
  9. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    I think some one on this chat has a new improved hybrid battery different from the Toyotas? He's got cylindrical modules in them.
    I think he's 2kcosta or something? Can't remember now
  10. Deft Jef
    Deft Jef Junior Member
    27
    Chicago
    Last I heard he is selling his batteries for $1600. He may have to lower his price a couple hundred dollars to justify purchasing one of his batteries over a $1625 Toyota battery.
    kenoarto likes this.
  11. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Wao! If there's a Toyota battery for such a cost, then I'd go for it.
    Is the $1625 inclusive of tax,labour?
  12. dolj
    dolj Senior Member
    7,652
    3,865
    No, it just the price of the part. Taxes and labor are extra.
  13. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    If you buy the part & install it there is a 1 year warranty. Dealer install gives a 3 year warranty. I understand that the @2ktToaster kit has a 2 year warranty.
  14. strawbrad
    953
    999
    The list price for a new Gen 2 battery is now $1950. Independent repair garages can get a wholesale discount in the $1625 range. It is difficult but not impossible to find a dealer that will sell for less than list price. Many Toyota dealers will not sell a battery to the public for any price.
    m.wynn and Prodigyplace like this.
  15. ChapmanF
    15,605
    A high-voltage leak (if it's in the battery) is the kind of problem that may be quite fixable (as opposed to, say, tuckered-out modules, which just have to be replaced).
    -Chap
  16. kenoarto
    396
    Chicago, IL
    OK, but don't you think that unskilled delivery should be charged at a minimum rate rather than a full mechanics rate, because many other things are being picked up in deliveries? Sounds like 2 hours is more than enough chargeable mechanics time to do the actual work.That's makes it about $125/hour.
  17. Kimberly Lands
    Bull head City, AZ
    Four Touring
    Thank you all for the help. I do have another question though. How do I tell where this leak is coming from if their is a leak?
  18. Kimberly Lands
    Bull head City, AZ
    Four Touring
    How could it be fixed without buying a new battery?
  19. bisco
    49,479
    you need tech stream software for the correct codes, and then tech info at toyota.com for the service manual. this is not for the faint of heart.
    jaw444 likes this.
  20. strawbrad
    953
    999
    First, there is no doubt that your car has a high voltage leak. That is the one and only thing a P0AA6 code means.
    One way to pinpoint the leak is with Toyota's Teachstream software. That system can give you sub or info codes that will show the source of the leak.
    There is another way to locate a high voltage leak that takes just minutes and does not require any special tools. This test will not work if your car still takes 24 hours to detect the leak after it is cleared. Once the car gets to the point of immediately recording the P00A6 code after it has been cleared this test will be effective.
    The video shows the test being run on a Gen 1 that uses a conventional key. To get a Gen 2 to "on" but not ready leave your foot off the brake and push the power button twice.
    Until your car is properly repaired it is possible to keep driving it. You need to keep a code reader or tools to disconnect the 12 volt battery with you. Then you can clear the P0AA6 code whenever it comes back. This will allow the car to restart until the code comes back again.
    Chap was referring to the possibility of replacing just the leaky battery module. Phoenix Hybrid Batteries has found leaky packs to be very difficult to rebuild. Once one module leaks the rest of them are much more likely to leak also. It's caused by the extreme Arizona heat.
    Here is where the Gen 2 modules leak. It's not the same as the leaky terminals of the Gen 1 modules. The plastic battery module case cracks next to the mounting bolt. This module was under a slight over charge to give it just enough internal pressure for the bubble soap to work.
    Brad
    Raytheeagle and m.wynn like this.
