Does not charge if not charged daily
Discussion in 'Prime Main Forum (2017-2022)' started by Daru, Feb 9, 2018.
Tags:
  1. Daru
    Daru New Member
    My Prius charge schedule is set to charge every day at 12 AM. If I charge it Monday but not Tuesday or for several days, like if if I plug it in to charge on Friday, it says the next scheduled charge is the PAST TUESDAY, the day after my last charge. It does not keep track of what day it is and it will never charge again. I have to tell it Charge Now, but I want it to charge after midnight when rates are lowest, not NOW.
    Why doesn't it know what day it is and charge it the night I plug it in?
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Did you correctly set date and time both in MID and in NAV?
  3. Daru
    Daru New Member
    Don't know. I'll check tomorrow. Thanks for the suggestion....
    The clock is correct.. Does that mean anything?
  4. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Nope... Gotta make sure the dates are correct. Mine had the same issue... They set the wrong date at the dealer.
    priuscatprimeguy and vvillovv like this.
  5. Daru
    Daru New Member
    MID and in NAV?
    What are these settings? Thought I could find them, can't... Is this a dealer problem?
  6. Lee Jay
    5,850
    4,036
    MID is the right side display on the dash. Stands for Multi information display. It has a settings menu that includes at least a clock setting.
    NAV is the big center display. Stands for navigation. It also has a settings menu and a way to set date, time, daylight savings, etc.
    benagi and FuelMiser like this.
  7. Daru
    Daru New Member
    Thanks so much. I'll get at it today.
