Noise when the brake pedal
Discussion in 'Gen 4 Prius Technical Discussion' started by Furina, Feb 10, 2018.
  1. Furina
    Furina New Member
    UK
    Business Edition
    Hello,
    When I press my brake pedal I can sometimes hear a weird "crrrr".
    It does it when the engine is cold, even before starting the hybrid system, or at the latest within 2 minutes after starting.
    mp3 file in the .zip attached.
    Normal noise when pressing at 0:08
    Abnormal ? at 0:17.
    Thanks for you help.
    25000 kilometers , from 2016.
    51,772
    it sounds like a bad brake actuator, but not on a '16?
  3. Prodigyplace
    12,502
    11,735
    Central Virginia
    Have you had the dealer look at it? It may be a warranty repair.
  4. bisco
    51,772
    the first part sounds like the door locks.
  5. Furina
    Furina New Member
    UK
    Business Edition
    Unfortunately the concession did not find anything. It does not make this noise during all trips. About one in three ...
    In any case it does it only cold and I do not even need to turn on the engine for it to do.
    The noise is at 0:17. Nothing abnormal before. During the recording I pressed several times the pedal is what we hear before with the usual little noise when pressed.
  6. Furina
    Furina New Member
    UK
    Business Edition
    Another one this morning :
  7. toyolover
    toyolover Member
    441
    67
    toronto, canada
    My 2010 Gen3 never made such noise ever since I owned it. I don't believe there are any changes in the brake system for Gen4. Judging from your noise file, it is definitely not normal to my ears. I would ask the dealer to take a look. Even they may not find anything wrong but it should be noted in your service history for future reference.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    I don't understand what you said "even before starting the hybrid system"? So it makes the noise before you press the <POWER> button?
    Can you play your recording to the service department?
    Furina and Prodigyplace like this.
  9. Furina
    Furina New Member
    UK
    Business Edition
    Exactly.
    Exactly. It can makes the noise before i press the power button. Or also after. You have the two cases on my recordings. On the last one you can hear the noise before the powering "BIP".
    The latest I got was 2 minutes after I started driving.
    I can make listen to the dealership. Unfortunately it only happens on one out of three trips. I have no idea where it can come from and if it has consequences on my braking.
  10. alanclarkeau
    7,045
    7,592
  11. Furina
    Furina New Member
    UK
    Business Edition
    No. Ive theses "tiktiktik" too but if you hear my records its a big crrrr. Not the same noise
  12. alanclarkeau
    7,045
    7,592
    I listened to mine today - it started as I approached the car before unlocking - I reckon about 6 or 8 different sounds, almost like I'd imagine an electric flying saucer to make getting ready for take-off - but no "CRRRR", sorry.
    RCO likes this.
