Cyl 2 misfire oil in spark plug galley Now Cyl 4
Discussion in 'Gen 2 Prius Technical Discussion' started by DGESSWIN, Feb 11, 2018.
  1. DGESSWIN
    DGESSWIN Junior Member
    35
    Connecticut
    Ok my 283K 05 has been running like a cammed hotrod and gas mileage has been down to 35mpg exhaust is lopey. for a long time. I found oil in the #2 cylinder replaced the valve cover gasket and all of the plugs no change. finally through a misfire cylinder 2 code on Friday. pulled the spark plug on cylinder 2 there was oil on the threads. took out my camera scope and put it in the hole and sure enough there was oil in the galley. (not in or n piston it looked fine. inspected cylinder 3 and no oil. cleaned up the plug checked the gap and went for a test drive. went about 10 miles and misfire on 2 came back. cleared it. drove 1 mile and now cylinder 4 is misfiring and she's a bouncing. its frigging torrential downpour here and I don't have a garage. so I'm looking for any ideas to troubleshoot this thing. there is also what I would consider lots of valve train "chatter" I thought of replacing the head with a low mile used one for 100$. I need to do a compression test. I know that. Help!
    Thanks
    Don
  2. padroo
    padroo Senior Member
    2,763
    2,251
    Raytheeagle likes this.
  3. DGESSWIN
    35
    Connecticut
    that's one thing I didn't do. I didn't because of the oil all over the boot, ceramic and threads and the inside of the coil had oil in it to. so I ruled out the coil pack. like I said misfire is now on cylinder 4.
  4. padroo
    2,763
    2,251
    A cylinder leak down test would be more specific than a compression test.
  5. DGESSWIN
    35
    Connecticut
    yes sir. that's what I meant.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    What does “ oil in the galley” mean?
  7. DGESSWIN
    35
    Connecticut
    oil in the hole where the spark plug is threaded in. so its exposed to coil and ceramic of plug. its an industry term I made up.
  8. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Spark plug well.
    If you have oil in there you did not replace the v cover gasket properly. If leaking a lot of oil you may have damaged a cop (coil on plug) it may have shorted out from being soaked in used oil.
    Fix the gasket so it does not leak oil.
    Answer this question. Have you ever ran the engine so low on oil it threw a master caution red icon on th dash?
  9. DGESSWIN
    35
    Connecticut
  10. DGESSWIN
    35
    Connecticut
    why what are you thinking? warped head?
  11. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Engine overheat. Probably warped the aluminum head. The head warps pretty easy on a overheat.
    Really bad design you lose the belt you lose the water pump and no engine temp meter on the dash. By the time you see the overheat icon on the dash engine damage has ensued.
    DGESSWIN likes this.
  12. DGESSWIN
    35
    Connecticut
    I guess that I will bang that out. its the least expense 100$ for used head with warranty locally and I have had this thing apart so many times I can do it blind folded.
  13. RickyV12
    RickyV12 Junior Member
    I am newbie and really know nothing about car, my 07 Prius, 200+K miles, I ran into this situation, I changed motor oilsbut spilled due to too dark, 4 days late, it had P0302, misfire, motor oils inside all spark plugs/coilpaks, I clean all motor oils with clothes, and water, It ran fine for 2 days, pouring rains, it misfired PO301, I cleaned all coilpaks , it was still misfired, I noticed that coilpaks/rubber with brown motor oil stains, I guessed that those motor oils stains reacted to water = carbon = conductive, I sanded those motor oil stains on coilpaks and rubbers, car run well without misfire.
