What is purpose of this part?
Discussion in 'Gen 3 Prius Main Forum' started by TomasG, Feb 11, 2018.
  1. TomasG
    TomasG Junior Member
    17
    Lithuania
    Hi everybody,
    I wonder what is the purpose of this red thing near on panel. In my older car there was sensor for interior temperature. But it was a bit different (it had like little dots on it)
    I tried to read about it in owners manual but couldn't find confirmation that it really is interior temperatures sensor.
    What could it be?
  2. William Redoubt
    William Redoubt Senior Member
    1,228
    1,172
    Coronado Island, California
    It might be a daylight sensor or rain sensor. Do you have automatic lights or wipers?
  3. Mendel Leisk
    41,301
    I think that's light level detector, for controlling dash light brightness, for one.
    Interior air temperature sensor is in the lower dash, near your right knee when you're in the (left side) driver's seat, behind a little grill.
    Johnny Cakes and TomasG like this.
  4. TomasG
    17
    Lithuania
    I think I have neither one.
  5. TomasG
    17
    Lithuania
    That's really good idea. I'll try to cover it and see if it have any influence for brightness. Although sometimes brightness is a bit too hihg so I just rotate that wheel to lower the brightness.
    But from here comes another question. Does that click sound when rotating that wheel all the way to brightest position means something? Or it is just reminder that wheel is in its highesh position? Maybe this is auto mode for brightness?
  6. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    First of all, I think the light sensor is not used for controlling dash brightness. I believe that the climate control system uses it (along with other inputs) when on the auto setting to adjust settings like air intake fan speed, heater or air conditioner output, etc. It assumes that sun contributes to warming the car interior.
    When you go up past the click on the wheel you defeat the normal effect of dimming the dash when you turn on your headlights. If, for example, you turn on your lights on a rainy day but find the dash too dim, rotate the wheel up past the click to get full brightness. Anything below that will be dim compared to the normal daytime brightness.
    TomasG likes this.
  7. BZzap!
    BZzap! Senior Member
    1,607
    878
    Automatic headlight timer sensor. Can be toggled in setup display to turn offi/on.
    Setup>Vehicle>HeadlightAuto-Off Timer>Seconds delay or Off/On
  8. Mendel Leisk
    41,301
    If I recall correctly, pushing the wheel all the way to the top, through that click, it'll stay bright all the time. One below the click, the dash lights will dim if the sensor detects ambient light levels drop. You can notice this when you go under an overpass sometimes.
    I was reading up on the heat/vent this morning a bit, and there was mention that this sensor is also used by that system, which makes sense.
    TomasG likes this.
  9. TomasG
    17
    Lithuania
    In my car I can only see Maintenance option when I open vehicle settings. I read somewhere that lights turn off automatically after 30 seconds
  10. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    It is a light sensor for your automatic climate control. If you have "Auto" position in your headlight switch, it also senses ambient light so the headlights can turn on or off automatically. BZzap's instructions don't apply to 2010 and 2011 Prius models but it applies to 2012 to 2015 Prius.
    Mendel Leisk and TomasG like this.
  11. padroo
    padroo Senior Member
    2,763
    2,252
    I never knew where the sensors were. Where is the one that reads outside temperature?
    Raytheeagle likes this.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    In the front of the car, along the bottom edge of the bumper line;).
  13. RRxing
    RRxing Senior Member
    2,545
    1,820
    NEPA
    This is the correct answer...
