My wifes 09 vs my 08.
Discussion in 'Gen 2 Prius Fuel Economy' started by Astrong1984, Feb 19, 2018.
  1. Astrong1984
    Astrong1984 New Member
    Castle Rock Colorado
    Ok, Long post INC. See TL;DR at bottom :).
    I purchased my first Prius in May 2016. We got a 2009 touring with 119k (I think...) miles on it. Extremely happy with it. Now, less than 2 years later, we have 143k on it. For a while, I was using it as a daily driver in Texas making a 32 mile each way commute to work and back. It was our only vehicle for about 15 months (from the time we purchased it, to the time we got my truck). When I drove it, solely, I would see MPG around 44. It was being used 40/60 city/highway, and when on the highway I cruised at 80-85 MPH. So I was happy with those results.
    Then I got a truck, and we moved to Colorado. My wife was the only driver (90% of the time) of the Prius. I have read all the "Lower fuel economy in the winter" posts, so I was expecting lower. My wife is the type of driver who gets in, floors it at every green light and slams the brakes on at the last minute (despite me showing and telling her how to properly drive it...) So also expected lower fuel economy. Well as it turns out, my new commute is roughly 84 miles... (long story, even longer than this post). So we sold my truck :*(. I drove her car for about 3 weeks, and the best fuel economy I am seeing is about 36 mpg. Which, again, colder Colorado weather. Another factor is we have studded snow tires on her car...
    About 2 weeks ago, I picked up a 2008 with 117k miles on it. And here is where my concern comes into play. With my car, it feels as though I have a lot more power. And I am seeing 42 MPG when I don't try (AKA, drive like my wife) and 45-46 when I do try. (Again, this is winter driving)
    Before I got this car, I was happy with 36 mpg. Now I am concerned that I am seeing the beginning of the end of the HV battery.
    Here's where I need input:
    Should I be concerned about the HV battery in her car, or is the mileage difference and different tires enough to make that much of a change?
    I have read this entire post:
    Quantitative Results of Grid Charge Discharge
    And I have determined that if I do end up with a grid charger, it will be from Hybrid Automotive. @jeff652 was extremely active and more than helpful throughout that entire thread!
    TL;DR
    Have two prii, one gets better MPG, should I be concerned?
    jeff652 likes this.
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I think you are correct on all accounts as those all matter. Yes, with two Pri, you are a perfect candidate for a grid charger/discharger and beginning a maintenance program ASAP.
    Raytheeagle likes this.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Snow tires can be a major difference, if you love your jack you could swap them and see what the MPG does.
    There are other issues that can affect MPG, voltage of the 12 volt battery as an example, wheel alignment, or how full the oil is. While you can begin maintaining the HV battery, do not jump straight to that as a cause.
  4. bisco
    52,390
    too many variables. if you want to get the lower one up to snuff, you will have to do a lot of research and maintenance.
  5. Mendel Leisk
    41,901
    Having two of anything can be maddening. Sorry, rambling, need coffee. Then I'll ramble with purpose.
    Raytheeagle and pilotgrrl like this.
  6. Tideland Prius
    16,620
    Boulder Hybrids run by Paul Gusyk is a near-local hybrid shop if you wanna drop by and have him take a look at your cars.
    It's possible there cars are using two different fuel types (if the 2008 was sitting for a while, it could still be running on summer fuel leftover in the tank for example).
    I would go through a few more tanks and get an average... just to see if the 2008 is consistently getting better mpg or if it is a one-off.
  7. Astrong1984
    I will do the 12v check on her car when I see it next (should be on Thursday). Wheel alignment is good, and I do the oil and check it excessively (at least once a week). I am paranoid she will run out, and her car uses 1qt every 2-3k mi.
    And I would try swapping tires, but she’d have to drive my car because now that she has them, she says she won’t drive in winter without them lol.
    EDIT: Although, then it would give me the opportunity to drive her car with fewer variables... duh
    Yes. That’s why I figured I’d start with this post :p.
    I guess if I am desperate I could hit up Boulder Prius. I commute from Ft Collins to Castle Rock, so Boulder is not that far off my commute. My issue is, I don’t like other people to do any work on my cars. It seems like every time I give in, someone messes something simple up, and I’d rather be in control.
    I’ve been through 4 tanks, just filled up last night for the fifth time. The dealership I bought it from filled me up (it was the typical empty tank when I test drove it...)
    As much as I’d like to jump onboard that train, it’s hard to justify that to the wife ><. That’s a lot of money for a preventative maintenance procedure.
  8. bisco
    52,390
    oil burning may reduce efficiency.
  9. Tideland Prius
    16,620
    That's fair.
    He's also a participant on the What Drives Us podcast hosted by @Russell Frost
    Raytheeagle and Astrong1984 like this.
  10. Astrong1984
    Yeah, ok.
    Time to hook up the tech stream. I purchased one but have yet to use it. No time, too much working...
  11. padroo
    padroo Senior Member
    2,763
    2,252
    I know a guy who owned two Prii the same year I believe 2008. He wrecked the first one and bought a second new 2008 and he always complained the second one didn't get the gas mileage that the first one got. Sometimes there is no answer.
  12. JC91006
    JC91006 Senior Member
    16,827
    8,600
    I have 3 2005 Prii, all have different mpg. From 42 to 50mpg.
  13. fotomoto
    5,639
    3,815
    So. Texas
    Just to clarify, grid-charging isn't a one time procedure (usually month-6 weeks intervals) and the balancing/discharge procedure is once or twice per year so the equipment will get used a lot. So much so, you would definitely need two harnesses because trying to share one between two vehicles would be a major PITA. You can always sell the unit (quickly) when you no longer have a need for it and recoup some of the costs.
    Raytheeagle and WilDavis like this.
  14. Astrong1984
    And honestly? I would take that answer. I think I will finally hook up the tech stream and run a battery check. I will update when I have done that :p.
  15. Astrong1984
    Yeah, I’m aware of that, it’s just the upfront cost will be like $600 for both cars. And if my batteries are ok, then I would rather not right now :S.
  16. bisco
    52,390
    tires could be costing you 5 mpg, what's on the other car?
  17. fotomoto
    5,639
    3,815
    So. Texas
    Preventive maintenance is done before you have an issue to (hopefully) avoid said issue as long as possible. Grid charging isn't a cure/repair for a failed battery. IOW, we don't wait for an engine to begin burning oil before starting regular oil changes.
  18. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Is that still going? The last one I see listed on the Boulder Hybrid and the What Drives Us web sites is May 18 of last year. Another project that Danny disappeared from.
  19. Tideland Prius
    16,620
    I thought so (I haven't participated in a while).
    Here's the channel
    What Drives Us - YouTube
    Here's the latest one. Small group since it was Valentine's Day - Russell, Mark and Paul.
  20. royrose
    1,389
    953
    Foot of Pikes Peak
    Thanks. I had a vague recollection of having found one since last may but got thrown off by the web sites that haven't been updated.
    Does Danny own the whatdrives.us website? I am glad that they have gone on without him.
