Changed 2009 prius pcv valve after 96k miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by epoch_time, Feb 2, 2018.
  1. epoch_time
    epoch_time Active Member
    236
    110
    las vegas
    Well I finally installed new pcv valve that I purchased 6 years ago (part number 12204-21011).
    I had put off installation due to the excessive removal of parts for access to pcv valve.
    I removed the airfilter housing, relay box, loosened cable harness, disconnected injectors and spark coils.
    Pulling loosened wire harness forward allowed access to pcv valve. There are some good youtube videos showing how to do it without removing cowling and window wipers.
    I had to use a deep impact socket and a pipe wrench to turn the socket to remove pvc valve.
    Anyway the pcv valve looked perfect after 96k miles. Probably because I've alway change/used mobile 1 5-30w extended performance synthetic oil at 4-5k mile intervals. I've owned the prius since new with only 8 miles on it. So I know the pcv valve was never changed till now.
    The Old pcv valve rattles like the new one and seems to be good. With the new valve installed the prius runs much better.
    Less misfires (displayed with torque apk). No more pinging. Smother gas engine starts and stops. More acceleration with less gas pedal depression. No more hesitation on acceleration.
    I thought my prius was running great before I changed the pcv valve getting 50+ miles per gallon.
    Now it runs even better.
    The old valve blocks flow toward engine and allows flow away from engine. I suspect a new valve might block both directions depending on internal spring tension within pcv valve. I went to toyota dealer to purchase another new pcv valve so I could check if it allows flow away from engine.
    Toyota says there are two part numbers for pvc valve for 2009 prius and they are out of stock on both.
    Toyota wanted to know my vin number to provide the right pcv valve.
    The two part numbers are 12204-21011 and 12204-21012. Dealer doesn't know why or what the difference is. My early model 2009 purchased in december 2008 uses 12204-21011 pcv valve.
  2. JC91006
    JC91006 Senior Member
    16,828
    8,601
    You're experiencing the placebo effect
    Kevin_Denver, SFO and Mendel Leisk like this.
  3. Mendel Leisk
    41,921
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Would be great if you had a vacuum pump or pressure pump and could test with and report your findings on both the New and Old valves.
    2009 was the year Toyota switched from Gen2 to Gen3.
    Raytheeagle likes this.
  5. Mendel Leisk
    41,921
    Not sure what you're saying. OP probably knows what gen he has: model year 2009 gen 2, purchased December 2008?
  6. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Was saying this could be the reason for the differing part number(s) and or why the parts jockey wanted to go by the VIN.
    "Third generation (XW30; 2009–2015) - Toyota debuted the new Prius (2010 US model year) at the January 2009 North American International Auto Show, and sales began in Japan on 18 May 2009."
  7. Prodigyplace
    12,682
    11,833
    Central Virginia
    I remember reading from one of our mechanic users here that you cannot properly test the valve by shaking it.
    They may be actually experiencing improved economy.
  8. Mendel Leisk
    41,921
    Does a failing PCV valve cause a drop in mpg? Not sure. To further complicate matters, it can fail open, or closed? I'd suspect there was nothing wrong with OP's, but it doesn't hurt, preventative maintenance.
    Prodigyplace likes this.
  9. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Not sure the OP has realized any gains in MPG, or reported any losses.
    Would be interesting to know the OP's ratio of city/highway driving and at what average speed(s), not to mention any previous oil usage or lack thereof now that the PCV is new again.
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    I don't understand this.......wouldn't that be called a plug?
    Positive Crankcase Ventilation = any pressure in the engine internal volume due to compression/combustion gases leaking past piston rings vents to the low pressure (vacuum) of the intake system and gets recycled back to the combustion cycle. In the big scheme of things, a vacuum in the crankcase is most efficient as it provides less resistance to crank/rod/piston motion..
  11. epoch_time
    236
    110
    las vegas
    1200 miles later after changing pvc valve and getting approximately 15% increase in ice output.
    I'm trying to understand why the substantial increase in power to the point of being overly concerned.
    I Thought my prius was running perfect before changing orignal pvc valve. Its now better than perfect!!!!
    I am now worried that this large increase in ice power is adding much more wear and tear on my internal combustion engine. I have accually lost about 2mpg with the new pvc valve and increased the ice output.
    I have tried to come up with many theories for the increase in ice power (excluding PVC) including but not limited to;
    A; Fresh electrical connections to the spark coils and to the injector coils (after disconnecting and reconnecting them).
    B; Cleaned some caked up dirt off the outside of the mass air flow module (orignal maf now has 97k miles).
    C; Blew out Small amount of dirt from allready clean looking air filter.
    If you change your PVC valve I would add a drop of oil from your dipstick into the bottom of new PVC valve (and shake).
    I didn't do this. But occured to me that the pvc internal piston/slug could use some preliminary oil lubrication to make it last longer.. Its probably this piston/slug that wears out.
    Being overly concerned with increased power, slight loss in mpg (2Mpg), additional engine wear. I decided to reboot all the computers/ecu's disconnect 12v battery) and let new fuel trims to be learned.
    This reset/reboot of ecu's was about 300 miles ago and there is no difference still to much performance.
    I guess the hessitations (and misfires) of the ice on the old PVC (which appeared to be in perfect condition) was a gas saver hehe.
    My prius is driven mostly city miles, Doesn't burn any oil yet (might start burning oil now that engine is putting out more power). I was seeing 30 to 50 misfires per drive as seen on torque apk (couldn't fill it at all). Now I see one to three misfires on the torque apk (this is with orignal spark plugs 97kmiles old).
    Summary the prius pvc valve is a precision part that does wear. lubricate (lightly) before installation!
  12. Mendel Leisk
    41,921
    How are you measuring engine "output"? Seat-of-pants feel when accelerating?.
    SFO likes this.
  13. epoch_time
    236
    110
    las vegas
    Yes seat-of-pants feeling
