Normal front brake pad replacement interval?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lenjack, Feb 20, 2018.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    2010 Prius 3 with 120 k miles. My local gas station guy , who I trust, says I soon need new front pads. Is this about right for this mileage? Mostly non city driving. Thanks.
    52,194
    it's pretty varied, but 120k is not uncommon. if you're concerned, just ask him to show you the pads.
    and make sure he is competent with prius brake pads.
  3. Mendel Leisk
    41,753
    New pads are 10 mm thick, and service limit is 1 mm (my threshold would be 2~3 mm)
    My latest front brake check, the pads were at 7 mm remaining thickness (3 mm wear), this was at 66,400 kms. Doing a bit of a ratio equation, and then converting the kms to miles, at my present rate of wear, I think I'd down to service limit with around 124500 (miles) on the odometer:
    (It's basically 66,400 times 3, then times 5 and divided by 8)
    Yeah, I'd second that he be careful doing Prius brakes. Safest is to disconnect the 12 volt at the outset, to completely prevent possibility of the brakes pressurizing while the caliper's off. Also be careful when pushing in the pistons, they are plastic, so avoid any point loads, use even bearing. Also, before reconnecting the battery or starting the car, tromp the brake pedal multiple times, to take up any excess travel in the pedal, which could otherwise throw a code.
    I've attached a repair manual excerpt.
    #3 Mendel Leisk, Feb 20, 2018
    Fostel and jerrymildred like this.
  4. padroo
    padroo Senior Member
    2,763
    2,252
    I replaced my Gen 2 at 90,000.
  5. lenjack
    804
    114
    Pennsylvania USA
    I'm gonna do it myself. via the nutz to boltz video. Good idea?
    Raytheeagle and jerrymildred like this.
  6. bisco
    52,194
    always.(y)
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Wife's original front brake pads are at 6mm after 121,000 miles on her '07. Driven & maintained properly, Prius pads should last a very long time.
  8. Mendel Leisk
    41,753
    Yeah, a lot of level roads, few stops, vs a lot of stop-and-go, would make a difference I think.
    Just with a wheel off, looking through the little opening in the caliper, you get an edge-on view, can see the remaining pad depth.
    Again, if I saw only 2~3 mm left I'd seriously think about replacing; I suspect there's less heat transfer due to less mass, and they're more prone to fragment at the edges when they're that thin.
    Tommgb and jerrymildred like this.
  9. lenjack
    804
    114
    Pennsylvania USA
    Without taking a wheel off, they seem pretty thin. I'm going to take a wheel off to check.
  10. Mendel Leisk
    41,753
    Yeah I think the outer pad you can eyeball better just looking in obliquely, and the inner you have to rely on that opening in the caliper. There's slots on the pads, visible through that opening: if they're gone they're getting pretty low, maybe not quite mininum though.
  11. lenjack
    804
    114
    Pennsylvania USA
    Took wheel off. Less than 2 mm outer, maybe 3 inner. Prefer using jack stand for this, which I have. Where is the front jacking point for my floor jack? I have 2.
  12. Mendel Leisk
    41,753
    Page 423 of Owner's Manual shows this:
    It's in the largish circular opening in the engine underpanel.
    As to where to put the safety stands, I'm not a fan of the scissor jack locations, as shown in the manual. They're ok for the scissor jack, which cups around the lower edge and actually bears on the body behind, usually denting it a bit in the process. But for safety stands, I find the leading edges of two longitudinal body rails much more sturdy:
    And best to use these at the rear wheels:
    Raytheeagle, bisco and jerrymildred like this.
  13. lenjack
    804
    114
    Pennsylvania USA
    Thanks. I'm not quite picturing this. Would you kindly elaborate?
  14. Mendel Leisk
    41,753
    Front and rear safety stand points I use, marked in red (front to the right):
    (The distinctive L-shaped brackets are quite close, help you get your bearings.)
    (With the rears, I turn the safety stand cradles 90 degrees, works better.)
    Raytheeagle likes this.
  15. padroo
    2,763
    2,252
    Good picture Mendel, perfectly clear now.
  16. Dan05979
    Dan05979 Member
    181
    101
    New York City/Upstate NY
    I changed my rear rotors & pads around 130K and now my fronts are very low & rusty rotors which i'm about to change with 145K miles. I bought the car used in 2015 with 50K so these brakes do last long. 98% of my driving is highway.
  17. juniperala
    juniperala Junior Member
    22
    Houston, TX
    123K 2015 Prius. I am not having any issues but the independent shop was doing a health check for me and says it's time to replace the front pads AND rotors as the pads are at 10%. Won't tell me actual thickness of either of them, $597. Is this a lot?
    comes with 2 year guarantee
  18. bisco
    52,194
    it's a decent price, but get a second opinion, you need the pad thickness measurement to compare to toyota minimum specification. there are too mant scammers out there.
    juniperala likes this.
  19. Mendel Leisk
    41,753
    I’ve never understood that percent description. Anyway, IF they’re not fibbing, that’d be around 2 mm remaining, just considering new they’re around 10 mm, and bare minimum is 1 mm. If I had the pads out and they were down even to 3 mm, I’d replace.
    In about 45 years with cars I’ve had to change rotors once. We’re not in the serious salt belt though.
  20. bisco
    52,194
    'doing a health check' makes me want to check my bank balance
