No power after removing HV switch
Discussion in 'Gen 3 Prius Technical Discussion' started by Mohammed Naser, Feb 23, 2018.
  1. Mohammed Naser
    Mohammed Naser New Member
    Nashville
    Was doing some work in the trunk area, removed the HV orange switch. Now the car won't turn on. It has power like lights and horn.
    I'm 100% sure I put the switch back on correctly
  2. JC91006
    JC91006 Senior Member
    16,827
    8,600
    You have to lock the orange switch
    Raytheeagle likes this.
  3. Danny3xd
    Danny3xd Active Member
    238
    149
    CT. U.S.
    Deleted
    #3 Danny3xd, Feb 24, 2018
  4. Mohammed Naser
    Nashville
    Locked it in and still nothing. Is there a way to reset it?
  5. JC91006
    16,827
    8,600
    Flip the switch and then slide it until you hear a click? It's a 2 step process
    Danny3xd likes this.
  6. Mohammed Naser
    Nashville
    I've done that and still nothing
  7. JC91006
    16,827
    8,600
    Disconnect the 12v negative for 1 minute. Then start the car
    Danny3xd and Raytheeagle like this.
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    At least on Gen 2, there is a fuse inside the lock out device, if it is blown, you need a new lock out device.
  9. Mohammed Naser
    Nashville
    Which part is the lockout device
  10. Hybrid Battery Exchange
    70
    Gresham, OR
    The orange plug functions as a bridge and a fuse. There's also 3rd component, 2 prongs inside a small plug, they complete a circuit telling the car that the orange plug is in and locked. It's possible that the 2nd component of this, a connector from the battery, has come loose and not making a connection with the plug even if it's properly inserted.
    padroo likes this.
  11. padroo
    padroo Senior Member
    2,763
    2,252
    Starting at 12:30 in this video he shows how to lock the " service plug grip".
  12. Danny3xd
    238
    149
    CT. U.S.
    Padroo, that was awesome, thank you! First few minutes, I thought he was well informed. Then he turned a wrench. Ya know a guy's worth in any field just watching him pick up a tool. He's an artiest. (Best carpenter I have ever met told me he could watch a guy pick up a hammer and know if he was the master or student that day. I'm sure thats how he got to be the best I have personally met)
    Thank you so much for posting. I stopped every thing and sat and watched that from beginning to end. (I'm still paying off replacing a battery as I was not comfortable with such high voltage. I dang sure will next time.
    Wut could go wrong? LOL, hold my beer and watch this......"
    padroo likes this.
  13. ChapmanF
    18,533
    (y) that he used the multimeter to demonstrate how pulling the service plug leaves no voltage between the output terminals, but (n) about not mentioning how that might not be true if there has been an isolation fault (HV leakage) code reported. I'd be happier if he had said "always verify this with your meter, rather than assuming."
    -Chap
