Hand held scan tool
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ryan Harrington, Feb 24, 2018.
  1. Ryan Harrington
    Ryan Harrington Junior Member
    51
    Louisiana
    What is the least expensive handheld scan tool that will bleed the brakes on gen 2 Prius?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Do you have a J2534 mini vci cable with Techstream?
    That paired with an old laptop can be had for cheap.
    Ryan Harrington likes this.
  3. Ryan Harrington
    51
    Louisiana
    I do. It keeps throwing errors saying it failed. I even tried installing different versions of techstream.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,415
    3,286
    Madison, Wisconsin
    - Android phone/tablet
    - Torque Pro app
    - Elm Bluetooth OBDII reader
    Cost you under $100 for all 3 items.
    Prodigyplace likes this.
  5. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    The immitation cables on Amazon and crapBay are of poor quality as you are experiencing 1st had. You mightnwant to try a locla shop thta has one for sale so you can test before finalizing your ourchase. Or, find a seller on Amazon that is a Prime shipper for the free returns.
    Those whomhave had issues, have reported pin connection issue. Perhaps younhave this same issue? Once the pins were straightened, or the wire was reconnected firmly, all became well.
  6. exstudent
    2,214
    905
    Torrance, CA
  7. ericbecky
    4,415
    3,286
    Madison, Wisconsin
    I posted to quickly.
    While this will help with general code reading and clearing, as well as live data, it is not the best tools for brake bleeding.
    Sorry about that.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    VXDIAG has full TIS software. It’s on sale for $68 at VXDIAG SHOP.
    I have one works good plug and play win7 or xp.
    Raytheeagle likes this.
