Warning lights all over dash display, squeal noise, power went off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jaw444, Mar 1, 2018.
  1. jaw444
    jaw444 Member
    283
    27
    San Fernando Valley CA Van Nuys/Sherman Oaks
    Tonight, my 2007 Prius with 76K miles on it was operating normally when i parked it at the market. When i came out, it started up and as i was driving out of the drive way i heard a steady high pitched squeal noise which i've never heard before, the seat belt noise was also going until i fastened the belt. I drove a short distance (50 yards?) and pulled into the Mall drive way, and all those lights were coming on on the display and squealing continued, ABS, check battery (i think), tires, and much more, yellow amber colored, and to the left of that was a large red triangle with an exclamation point in the middle, and the airbag image was on, kind of orange. The turquoise blue lights showing gas gauge, mileage, the transmission gear positions, were all on and flashing, this was happening as i pulled into a parking place. I noticed the brakes were weak or hard to press, though they worked reliably, just hard. As i was backing into the parking place turning the steering wheel, the steering seemed to jam, and it seems the power steering and power brakes had gone off. I got the car crookedly into the parking place.
    I called the Toyota agency, it was 6:30pm, i knew they were closed but took a chance, sales rep answered and connected me to someone in service who didn't know anything but told me how i could have the car towed there and leave my key in a box, they'd call me tomorrow. while i was waiting for him to come to the phone, the squealing started to fade, it didn't abruptly stop, it began getting weaker and fading, until it did stop.
    On the GPS display, a message came up that said something about 'transmission P...." and a bunch of other words i don't remember. It said to turn the car off and put the brake on and then start it up. But by the time i tried that, the power already seemed to be completely off on the car. no lights, except an orange image of something that looks familiar but i'm not not sure what it is, and under it is the word 'CHECK,' also in orange. it might be a little engine because it looks like it has a propeller on the left end of it, but maybe it's a battery with a fan? That was the only light left, everything else went off. When i tried to restart it with the brake on, no response to the power button.
    Then i called Triple A for a tow, but remembering something about how this kind of car isn't supposed to be towed, it's supposed to be put on a flat truck, i have a thing about it in my glove compartment that explains it.
    Triple A sent a truck and he looked at it and then under the hood and he got something he called 'jumper,' it didn't look like jumper cables i've seen before, it was smaller. He then started my car and it looked normal, the lights were normal, not warning lights. He turned it off and turned it back on. He turned off the external power (jumper) and the car was working normally without it.
    He said i could drive it home and said i should take it in tomorrow. Can anyone give me ideas about what this sounds like it could be? i googled it and found stuff about the special battery that costs thousands of dollars and has to be routinely replaced after several years, and that my car is kind of overdue for that, it's 10 years old. Also there was something about a brake actuator (?) which had a recall and Toyota replaced the part, which cost $2000, but only up to December 2017 ? Are there only catastrophic things this can be (as it appeared from all those lights and squealing and no power and shutting off). i was relieved to be able to drive home, with my groceries. Thanks for any experience with this or info. prius mid dash.jpg
  2. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    OMG! TOO MUCH Unnecessary info; have mercy on us. Do you talk like you write?
    This is all you really needed to state.
    1) Your 12V battery sounds like it is weak. It likely needs to be replaced given how few miles you likely drive, which means the 12V is in a constant state of discharge, which will shorten its life span.
    Learn how to assess the health of the 12V battery yourself and buy a 12V smart, AGM compatible battery charger
    Is my inverter coolant pump slowly failing? | PriusChat
    Post #5) How to apply a load.
    Post #8) State of Charge chart, AGM compatible battery chargers.​
    2) There are DTC (Diagnostic Trouble Codes) stored, since you have some critical warning lights lit up:
    Check Engine Light
    Master Warning Light (Red exclamation point w/in Red triangle)
    ABS​
    Get the codes read by a shop that uses Techstream software or another higher end OBD2 code reader; Toyota dealer (likely $100+) or a shop that specializes in Toyotas (unknown cost). Report back what the codes are.
    Consider Avi's Advanced Automotive. He's a very knowledgeable member here on Prius Chat, since he's a mechanic, and seems to have a good reputation. Private message him (Avi's Advanced Automotive) or call him. Don't know if the yelp page has current address.
    Hybrid Fix - 37 Reviews - Auto Repair - 3790 S Western Ave, Exposition Park, Los Angeles, CA - Phone Number - Yelp
    3) The squealing could be coming from various sources. SUSPECTED NOISE LOCATION WOULD HAVE BEEN NICE (front left wheel area, engine compartment near (some "part") , trunk near battery, under the dash, etc).
    4) Its is very concerning that the car would shut itself down. However, once the car received a jump to start, it began driving normally.
    Consider just having the car towed to a mechanic.
    5) Consider buying the Toyota Prius Repair and Maintenance book by Bentley Publishers. This will greatly enhance you knowledge of the Prius.
    6) Learn how to check the engine oil level, and add engine oil. Do this on a regular basis; the more frequent, the better.
    SFO likes this.
  3. Stevewoods
    Stevewoods Senior Member
    664
    1,247
    where I am
    Odds are pretty good it is the small 12 v that is in the rear of the car in the hatch (above the passenger side rear wheel).
    They are around $200 from the dealer for a Toyota brand. Around $130--$200 for a non-Toyota.
    Your description, which I do not criticize you for, really points to it.
    Not a tough job to do yourself. But, not as simple as most 12v batteries. Toyota would likely charge about $90 to put it in for you. Many places such as Batteries Plus advertise they will install car batteries for free if you buy the battery from them, but on the Prius it is a bit more involved, so most of them exclude the Prius.
    So, I know it all looked bad and was a bit disconcerting last night. But as car troubles go, this one is not too bad.
    The video below, even if you do not plan to replace your own battery gives a good overview of where the battery is located and how it is replaced.
    #3 Stevewoods, Mar 1, 2018
  4. jaw444
    jaw444 Member
    283
    27
    Steve, thanks for the hopefully good news!! i thought there was the under the hood battery, simple, i replaced it at least once before, i mean, i had it replaced (i'm not the least bit handy with cars). And then the "other battery," which i always heard costs thousands of dollars. Is that the one in the back you're talking about out or is there a third one? The expensive one is supposed to last a certain number of years and/or miles and then it will inevitably go. The last time i had someone out to charge my under hood battery (overhead light on overnight), we were talking about that other battery and he talked about the price range, and saying even the price of used ones is high, obtained at body shops, and those are hard to get, he said. So i'm confused because i thought i was looking at that.
    i just googled it, lots of links on a "battery pack" costing $2900, after a couple of price reductions. what is that?
    The video does have a lot of interesting info, like how to open the hatchback from inside. Once, i couldn't get it open and had to take it to the dealer, he said something wasn't right about the latch and might need replacing at some point.
  5. jaw444
    jaw444 Member
    283
    27
    Thanks for the feedback, i do sometimes talk that way under conditions of anxiety. Thanks for all the info. The noise sounded to me like it was coming from the general area of the front of the inside of the car, maybe under the dashboard, but hard to say. All the lights were coming on and the brakes weren't working, a lot going on.[/QUOTE]
    SFO likes this.
  6. Stevewoods
    664
    1,247
    where I am
    Obviously I am not going to guarantee it is the 12-volt, but if it started fine after the Jump....
    And, I understand about being anxious and babbling away. I do it, even when I am not anxious. :whistle:
    Since it sounds as if you are not going to do it yourself, drive it to Toyota and have it done. You could check their Web site beforehand, often they have service coupons and or parts coupons that may save you 10 or 20 percent.
    Should be around $300 out the door at Toyota.
    There are only two real batteries you need to worry about -- not counting other batteries such as the TPMS, FOB, etc. :eek:
    While it certainly could be the traction battery (the multi-thousand dollar battery that is actually under the backseat), lets hope not. And, from your description, I would seriously doubt it.
    Any competent mechanic will know. Good luck.
    Steve
  7. jaw444
    jaw444 Member
    283
    27
    thanks for perspective. i once replaced the under the hood battery and it was about $300, cheaper from the Auto Club's referral but i went to the dealer. i had a trusting long time relationship with the Toyota service advisor who always kept costs down and didn't try to sell stuff. Today i called about bringing the car in, i will be leaving shortly to do that, but sadly was told my guy isn't there anymore. So, i am definitely anxious about that too, but i'm sure i never had a battery in the back of the car replaced, only the front one. i will check for coupons.
  8. Prodigyplace
    12,710
    11,848
    Central Virginia
    Your Prius does not have an under hood battery. Your 12 volt battery is located at the right hand side of the cargo area. That is why it is important to have a battery with the proper external venting. You do not want the battery gases in the passenger compartment.
    The 2016 Gen 4 Prius was the first Prius with an under hood 12 volt battery,
  9. Stevewoods
    664
    1,247
    where I am
    Again, as Prodigy said, there is no under front hood battery.
    The small 12v under the hatch in the wheel well that the video shows and the several hundred pound traction battery under the backseat. And, again, the one you probably need replaced is the one in the wheel well as shown in the video.
    I have no idea what you had replaced under the hood -- maybe they said under the hatch (in the wheel well) and you heard under the hood.
  10. jaw444
    jaw444 Member
    283
    27
    i now realize that i thought the battery was under the hood because that's where AutoClub always went to charge it over the years and i didn't notice that there was no battery in there. o_O when the battery was replaced, i wasn't there, i dropped the car off. so now i know the truth :)
    I read about how the battery has to be adequately/correctly vented. Is that not always the case, and if not, why not?
    i dropped the car off at Toyota and got a call from them--yes, it's the 12V battery, yay. They charge $410--i guess that includes the labor. i also got a basic maintenance, minor service/12 point inspection, $120. When he called, he said the hybrid/traction battery is "fine," but he said the fan for it is clogged up and needs to be removed and cleaned and it needs a new filter, $156. He said the engine was "filled with carbon gunk" and needed to be cleaned, $189 so the total with tax is $869. i expected to have some stuff needed because it hasn't been serviced since late 2015. The car has only been driven 4000 miles since then. I had planned to take it in now anyway, for service and whatever it needed. Unfortunately, a month or so ago, i lost my keys, i'm using my back up set. i know the keys are in my house but i've looked everywhere i can think of, went through the wastebaskets, i was hoping they'd turn up. Not yet. So i told them to make me a new key because if i lose the only set i now have, that would be poor. Another $300.
    but after suffering the terror that it was the thousands of dollars battery, i alright, glad it's done.
    thanks for the info
    #10 jaw444, Mar 1, 2018
  11. JC91006
    JC91006 Senior Member
    16,933
    8,642
    You should bring your car to avi's advanced automotive near USC. he would charge you a fraction of what you're paying the stealership. Preying on people like you
  12. Stevewoods
    664
    1,247
    where I am
    The $410 charge, well, a bit steep, but it is the dealer. It's a 30-minute job and the battery itself should be no more than $250, plus $90 or so for labor, but you got it done.
    As far as I know, the fan is certainly something that needs cleaning sometimes, but again, a 30-minute job and as far as I know, there is no filter for it, but some of us have fashioned our own filters for it out of bubble gum and dog hair (sort of kidding, but there are some folks on here who have made their own filters just because it does not have a filter).
    But, if it were clogged it could cause some real trouble, so if you got it done, that is a good thing.
    The carbon cleaning, total BS in my opinion, but others could disagree.
    Anyway, you are now back on the road.
    So, in my humble and not all that informed opinion, you could have saved at least the cost of the carbon cleaning. Yep, the other procedures were a little high, but....it's back on the pavement with the shiny side up -- something to be said for that.
    Prius battery cooling fan cleaning, P0A82 - Luscious Garage | Hybrid Specialists
    #12 Stevewoods, Mar 1, 2018
  13. jaw444
    jaw444 Member
    283
    27
    I really appreciate the referral to Avi, exstudent provided the address above. i thought about it. I'm in the Valley and i didn't want to drive that far in all the traffic, not knowing if my brakes were going to go out without warning like last night, or if the car would shut itself off in stop and go traffic on the freeway. I also had stuff to do today at home and didn't want to lose the whole day being over there waiting for the car. The Toyota dealer is walking distance from home, less than a mile.
    I've always taken the Prius to the agency, Keyes, since i got it except when i lived in Santa Monica, i went to the dealer over there, always felt overcharged there but not so much at Keyes. i did have a supportive cost saving service advisor who kept expenses low. Now, he's suddenly gone.
    i looked at my old service receipts today--just routine maintenance, most of them around $100 or less. The battery was replaced in 2014, $342 including tax. What i was charged there didn't seem out of line, though more than an independent mechanic. The service rep today told me the key fob was going to be $300. i was charged $357. I don't know why on the phone he told me the battery was $410 (including tax) but on receipt it says the battery was $334 (not including tax), which is the same as i paid in 2014. Anyway, the total the guy gave me on the phone was what i was charged. But the prices of the key fob and battery were both different from what he told me. Confusing. I'll call tomorrow and ask.
    I will go to an independent mechanic in the future. It doesn't work for me though to have to travel from the Valley to LA to have my car worked on and to have to sit around there and wait for it. I need to find someone near me.
  14. jaw444
    jaw444 Member
    283
    27
    On the receipt it says the battery was $208 and labor was $125. i don't know why he said $410. It adds up to what he said it would. And the different numbers he gave me on the phone add up to the same total. On the phone he said the key fob was $300. On the receipt it's $357.
    That's the kind of thing my previous service advisor since 2009 would have told me was optional. Since i haven't had it in since 2015, i figured it must need whatever. I could have trusted my other guy. Chalk that one up, and thanks, i'll remember that if it comes up again.
    my sentiments exactly. Since i thought the seemingly catastrophic symptoms last night meant the several thousand dollar battery was going, i have the feeling of dodging a bullet, not bad , however illusory.
    (i don't know if did the quotes right, no option to preview so it may come out weirder than ever. here goes nothing)
  15. jaw444
    jaw444 Member
    283
    27
    Thanks--i never knew that. I could drive it a little bit every day, i wonder if that would be enough. Like less than 5 minutes.
    Ok, that sounds good.​
    The service rep said there were no codes, except for something like 'low battery,' he said it as if it wasn't important. i don't see a charge on the receipt for it.
    Thanks, i'll look at that. It sounds useful.
    That's one thing i know how to do. when i was a kid, my first car was a Morris Minor 1000 with very high miles, i bought it for $50 and it burned oil, and i had to add oil as often as i got gas, keeping cans of oil in the trunk. i never have thought the Prius was burning oil though, with low miles. If i check it often and it doesn't go down, why would i keep checking it often? i guess they burn oil at some point. i haven't had a car that ever burned oil in decades, including the Accord i had that was at 165,000 miles and the dealer rep said it had 3 oil leaks, $1400, don't drive it, he lied. didn't believe him. i kept using it for work, but i started checking the oil regularly. It never went down at all. But that's what inspired me to get the Prius, time for a newer car because so much driving on my job. also it was the year that gas prices went to $5 per gallon, that was a big part of the inspiration.
    thanks for the info/suggestions
  16. jaw444
    jaw444 Member
    283
    27
    lol -- so, when i looked at the receipt, it wasn't a filter for the fan. It says REPLACE HYBRID BATTERY FILTER. Is there not one of those either?
  17. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    If you see a part # G92DH-47020 listed ($20), than you had this updated piece of plastic installed in the back seat passenger side :
    If you don't see the exact same piece of plastic, then I would ask for a refund, as there is no disposable HV filter to replace.
    If the $156 was labor for cleaning the HV battery fan, that's a normal stealership overcharge, even if the job took 30 mins or less.
