Trunk leak: Where exactly is the drain plug under 12V battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AaronPDX, Feb 28, 2018.
  1. AaronPDX
    AaronPDX Junior Member
    Oregon
    I've read so many helpful posts here about the leak issue. Mine's a 2008. Unfortunately there's an inch or more of water under my 12v battery and I see no drain plug from the underside -- and visibility from above is minimal, without removing battery which I'd really rather not do unless necessary. Can this mystery drain plug I keep reading about be located from below? If so, can someone tell me explicitly where?
    Thanks!
    52,091
    if there is a drain plug, it has to be visible from below. it's not that big an area, take a look around.
    but you really should remove the battery and clean things up.
  3. AaronPDX
    Oregon
    I agree, it should be obvious. I've already taken a look around, and It's not obvious for me. Yet others state it exists. Hence this post.
    I'll see if I can take out the battery tomorrow.
  4. Stevewoods
    Stevewoods Senior Member
    662
    1,147
    Seattle, WA
    I took the photo below from the following page. Interesting reading -- the battery was stuck in a block of ice. The photo is fairly far down the page. Here's the pix.
    and a link to the page:
    Prius 12V Battery Replacement and the Ice Pick
    He says it is a rubber plug and you can see the pavement below in this pix. He says he left it out when he re-installed the battery.
    #4 Stevewoods, Mar 1, 2018
    Raytheeagle, AaronPDX and srellim234 like this.
  5. AaronPDX
    Oregon
    Thank you Steve! That is a helpful pic, and now when I'm underneath I'll at least have a relative idea of where the plug is... Fingers crossed and hoping it's removable from below...?!
  6. Mendel Leisk
    41,640
    Just pull the battery, then throw a towel in there? Remove, wring out, repeat as needed.
    Raytheeagle and bisco like this.
  7. Stevewoods
    662
    1,147
    Seattle, WA
    What mendel, you don't like the guy's description of siphoning out the melted ice water and spitting it on the ground?
  8. AaronPDX
    Oregon
    Update: Found it! Not as obvious as I hoped with that picture in hand (that being taken from above, and me being positioned below with very little head clearance), but the rubber material was obvious and a bit of prying with a screwdriver loosened it enough to let a drip start flowing. Drained at least a quart of water! No battery removal required!
    I then pryed up the 2 weather seals on the roof sides, and cleaned underneath. Both rear edges of the rain channel/gutter/trough seem to have microfractures as reported elsewhere in this forum. So I cleaned with isopropyl and a toothbrush, dried and applied silicone sealant, which proved a little tricky since it's transparent and I was relying on ambient outdoor (Oregon winter) light. Not to mention you need a super-thin swab tool to get at the channel in its thinnest portion.
    Pix:
    Plug, removed:
    Plug location -- near the R rear wheel. (Someone please confirm that's the right hole! I took several pics really awkwardly with my phone down there and it was hard to tell) plug loc? .JPG
    Spare tire well: I removed plugs there in anticipation of more rain, replacing with plastic with a hole in center for drainage, duct taped. Temporary measure only, I hope!
    Fracture, rear left side:
    Fracture, rear right side:
    Raytheeagle, bisco and Stevewoods like this.
  9. Stevewoods
    662
    1,147
    Seattle, WA
    Guess I should probably check our battery well. But, it is cold outside and I am inside nice and warm and dry -- sipping a "Papa Doble" <The Hemingway recipe> and listening to "Old and in the Way."
    “I drink to make other people more interesting.” –Ernest Hemingway
    #9 Stevewoods, Mar 1, 2018
    AaronPDX likes this.
