thirty thousand mile mark
Discussion in 'Gen 4 Prius Fuel Economy' started by krmcg, Mar 2, 2018.
  1. krmcg
    2,592
    2,392
    Whittier, CA
    I have (almost) reached the 30,000 mile mark.
    Calculated MPG 61.7
    Displayed MPG 64.5
    Average cost per mile .043 cents - total cost $1291.36
    Average 623 miles per tank - 10.1 gallons per fill-up
  2. krmcg
    2,592
    2,392
    Whittier, CA
    I tried to attach the spreadsheet, but won't take...
  3. Mendel Leisk
    41,861
    Make sure it's xlsx format, not xls. The latter is older format, Priuschat won't accept.
  4. bisco
    52,351
    well done!(y)
  5. sclevine
    sclevine Active Member
    167
    160
    Northeast Florida
    2024 Prius
    @krmcg
    Nice, that's awesome mileage!
    Question - how do you get 10.1 gallons on average? How far past 0 miles-to-go do you let it go? Or do you top it off as much as possible? 9.7 is about as high as I've gotten.
    Tyfly likes this.
  6. krmcg
    2,592
    2,392
    Whittier, CA
    I almost always wait until the "empty" light comes on before I fill the tank. Even go past the DTE is down to 0 at times. l have had a few 800+ mile tanks. Not particularly smart of me I know, but I've never run out of gas. Just like to live on the edge I guess. I do not "top off" the tanks, at most I go to the next round dollar amount after the first click. The most gas I have ever put in was 11.2 gallons.
    RCO and Mendel Leisk like this.
  7. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    One more month before I hit 10k myself. Still going strong like the day you bought her?
  8. krmcg
    2,592
    2,392
    Whittier, CA
    better than ever. I have retired and no longer have the daily eco-friendly commute that I once had, so my MPGs have generally decreased. But I can still get great mileage when the road allows... The lifetime numbers would be even better but I took a 5,000 mile road trip last summer and averaged only 50.9 MPG on that trip.
    RCO likes this.
  9. padroo
    padroo Senior Member
    2,763
    2,252
    I don't drive near as much retired as I did when I worked. Owning a Prius and not driving as much makes gas one of my very minor monthly expenses. When grass cutting season comes I spend more on mower gas than car gas. lol
    It would be nice if Toyota made a Prius mower. :)
    pilotgrrl, Tande, RCO and 3 others like this.
  10. axle2152
    axle2152 Active Member
    266
    210
    Atlanta, GA
    2018 Prius Prime
    I must drive a lot...I guess that would make sense given that I live in the sticks in the appalachian mountains. I don't have the exact odometer but I'm somewhere around 43,000-44,000 miles and purchased mine back in August 2016. The lifetime mileage 55.2 MPG (US). The best single tank was 666.1 miles and used 10.459 gal at 63 MPG. Worst tank was 354.5 miles and used 8.063 gal at 44 MPG.Most of my driving is rural at speeds 45-70 MPH, not much of city or interstate driving unless I am on a trip. Where you drive, when you drive and how you drive make all the difference and why there are those who can achieve 800 miles on a tank and those who can barely crack 500.
    Since I've got the OBDII reader I have learned a few things. If the HV battery is cold, or under 83 degree, you won't get the full 21kW until it has warmed up, along with all the other factors regarding temperature. So the longer your commute in cold weather your fuel economy won't take a big hit, provided everything gets warmed up.
    krmcg, RCO and padroo like this.
  11. padroo
    2,763
    2,252
    That makes sense because as you draw power from a battery it will make it's own heat
  12. axle2152
    266
    210
    Atlanta, GA
    2018 Prius Prime
    The power output is limited until the battery gets over 80-85 F, which in cold weather that will probably take a while, longer than most people would be commuting. In most situations you really have to drive in stop and go traffic, city traffic or drive fairly aggressive to heat the battery up. The battery heating up is technically wasted energy, the more efficient something is (in this case the battery) the less heat (and other forms of energy) is created.
  13. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    Gently up and downhill stretches at 50-65 mph help with this too as the regenerative braking and electric motor assist move quite a bit of current in and out of the battery thus warming it quite efficiently.
    RCO, padroo and Mendel Leisk like this.
  14. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Sadly, the sheep which designed our Cornish highway routes didn't consider gentle climbs and descents in their methodology.
    krmcg, Mendel Leisk and jerrymildred like this.
  15. bbald123
    386
    275
    Harrisburg, PA
    Indeed, Geografie uber alles!
    RCO likes this.
