Possible Monthly install meets. Bay Area-Fremont
Discussion in 'Local Prius Club Main Forum' started by Priusmpg, Jul 1, 2014.
  1. SlidingBike
    SlidingBike Active Member
    171
    113
    Fremont, CA
    Advice please: Is this the correct engine oil for my PiP ? Mobil 1 High Mileage 0W20, 5 qt - Walmart.com
    OW20 Advanced Full Snyth of 5QT ? Planning to pick it up on my way.. :)
    Thanks..
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    How many miles you got on your pIP?
    High mileage isn’t what you need yet probably.
    Just the regular 0w-20 will work.
    SlidingBike likes this.
  3. SlidingBike
    171
    113
    Fremont, CA
    I got some where around 35K miles on my PiP.. Thanks for your quick attention..
  4. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    I thought you were in the lower mileage range ;).
    5 quarts of 0w-20 will give you some extra:).
    You got an oil filter:whistle:?
  5. SlidingBike
    171
    113
    Fremont, CA
    Weather here is very bad, thinking of not driving that far. I may not show up.
  6. Norcalgoat
    Norcalgoat Junior Member
    Pacifica, CA
    thank you
  7. Norcalgoat
    Pacifica, CA
    Want to thank everyone for recommendations for engine replacement, I have had zero luck so far, everyone wants $8K and no one does used motors
  8. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    One member had some luck with Maxat in Sacramento. I think they wanted $3k for the job but not sure if that was for the labor or also the engine and labor. I know @Joele3 was going through a decision on engine replacement, so maybe he’ll chime in:whistle:.
    Worth a call though;).
  9. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Did you try Luscious Garage in San Francisco?
  10. w84me
    w84me Active Member
    144
    224
    Sacramento
    Is there a new date?
  11. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Next Saturday the 17th from 10-5 in Lafayette at Smart Pedal HQ(y).
    SFO and w84me like this.
  12. w84me
    w84me Active Member
    144
    224
    Sacramento
    I might be able to finally make this haha
  13. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Just for the social aspects, or with something to accomplish :whistle:?
  14. w84me
    w84me Active Member
    144
    224
    Sacramento
    Just for social. I’ve nothing to install or any maintenance
    SFO and Raytheeagle like this.
  15. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Another successful meet up today at Smart Pedal HQ:).
    Thanks to @Pedal Logic for hosting;).
    It was nice to have @SFO , @priusSF1329 , @PriusFruit , @grid , @w84me and @Spooled participate :).
    Jobs completed:
    • Oil and engine coolant change for @PriusFruit ’s Gen2
    • Trans drain and fill in @Pedal Logic ’s Gen3
    • Oil change and rear brake pin lube on @grid ‘s Gen3
    • Egr pipe cleaning (which revealed the next steps), headlight bulb replacement, MAP sensor and MAF sensor cleaning on @priusSF1329 ’s Gen3
    • TRD rear sway bar install and passenger seat beep and reverse beep change on @Spooled ’s Gen3
    So a busy day:).
    Glad everyone was able to attend(y).
    gta_, PriusFruit, edspecR and 4 others like this.
  16. w84me
    w84me Active Member
    144
    224
    Sacramento
    DE533BF5-EB5F-44A5-9EB9-718E815BAE0A.jpeg 43F1D3D9-AB27-4C72-B7E7-2282B9C9330A.jpeg Had a great time. Thanks to mark for hosting. Hope to make another one
    SFO, Grit, PriusFruit and 1 other person like this.
  17. gta_
    gta_ Active Member
    189
    134
    Tracy, CA
    Any of you guys happen to be going over the altamont today around 430-440 in a white PiP with black or dark gray aftemarket wheels (looked like 17s, we were moving so I couldn’t say for sure). Saw it on my commute and was curious lol.
    SFO likes this.
  18. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    So it’s been about a month since the last meetup. I know I have gotten a couple of PMs from some asking about the next meetup, so let’s see what we can put together :).
    Most upcoming weekends work for me, but not sure what works for others;).
    And anyone want to host:whistle:?
    Grit, gta_ and SFO like this.
  19. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Will sign up for an oil change, unless taken care of before the next meet up.
    gta_ and Raytheeagle like this.
  20. edspecR
    edspecR Member
    136
    94
    Berkeley
    i definitely need to do an oil change, hope i can make this next one
