CAN-view cheapest way to get a backup camera in an '05?
Discussion in 'Gen 2 Prius Technical Discussion' started by phileFriendly, Jul 25, 2006.
  1. phileFriendly
    phileFriendly New Member
    25
    WA
    So I keep thinking about adding a CAN-view to my non-NAV 05 Prius because I want a backup camera. Would this work?
    1) CAN-View version 3 $400
    2) GrandTec GVC-1000 video->VGA converter $75
    3) Backup camera from eBay $100
    Would the CAN-View v3 work with the video->VGA converter (which I believe is designed to basically turn your computer monitor into a TV)?
    Is there any other option that would be cheaper? $600 seems pretty steep...
    Thanks!
  2. lee
    lee New Member
    62
    Rochester, NY
  3. eflier
    eflier Silver Business Sponsor
    164
    Fraser Valley BC
    <div class='quotetop'>QUOTE(phileFriendly @ Jul 25 2006, 06:04 PM) [snapback]292311[/snapback]</div>
    Technically I'm on vacation but here goes anyway:
    Buying a CAN-view just to get the external video input for a camera converter, plus the converter, plus the camera IS pretty steep, I agree. I designed CAN-view primarily as an information display, which after evolving a bit just happens to have an external video input you can plug the UK camera converter into (Not the Grandtec incidentally, thats a TV to VGA converter and the Prius is not VGA)
    Thats a bit like buying a plasma TV just to get the audio channel.
    Maybe you should look at Coastal's new Unlock hardware which is intended primarily for video/audio.
    http://www.coastaletech.com/new_page_73.htm
    It says it works on all Prius with and without factory NAV and at $175 doesn't need a converter
    Technically that may be more appropriate for what you want.
