THE WORSENING COSMIC RAY SITUATION
Discussion in 'Environmental Discussion' started by wjtracy, Mar 5, 2018.
  1. wjtracy
    wjtracy Senior Member
    11,365
    3,608
    Northern VA (NoVA)
    From SpaceWeather.com, apparently solar activity is declining, which is perhaps good news for climate change, but the net effect is more cosmic rays. Geez we can't catch a break here...
    THE WORSENING COSMIC RAY SITUATION:
    Cosmic rays are bad–and they're getting worse. That's the conclusion of a new paper just published in the research journal Space Weather. The authors, led by Prof. Nathan Schwadron of the University of New Hampshire, show that radiation from deep space is dangerous and intensifying faster than previously predicted.
    The story begins four years ago when Schwadron and colleagues first sounded the alarm about cosmic rays. Analyzing data from the Cosmic Ray Telescope for the Effects of Radiation (CRaTER) instrument onboard NASA's Lunar Reconnaissance Orbiter (LRO), they found that cosmic rays in the Earth-Moon system were peaking at levels never before seen in the Space Age. The worsening radiation environment, they pointed out, was a potential peril to astronauts, curtailing how long they could safely travel through space.
    This figure from their original 2014 paper shows the number of days a 30-year old male astronaut flying in a spaceship with 10 g/cm2 of aluminum shielding could go before hitting NASA-mandated radiation limits:
    In the 1990s, the astronaut could spend 1000 days in interplanetary space. In 2014 … only 700 days. "That's a huge change," says Schwadron.
    Galactic cosmic rays come from outside the solar system. They are a mixture of high-energy photons and sub-atomic particles accelerated toward Earth by supernova explosions and other violent events in the cosmos. Our first line of defense is the sun: The sun's magnetic field and solar wind combine to create a porous 'shield' that fends off cosmic rays attempting to enter the solar system. The shielding action of the sun is strongest during Solar Maximum and weakest during Solar Minimum–hence the 11-year rhythm of the mission duration plot above.
    The problem is, as the authors note in their new paper, the shield is weakening: "Over the last decade, the solar wind has exhibited low densities and magnetic field strengths, representing anomalous states that have never been observed during the Space Age. As a result of this remarkably weak solar activity, we have also observed the highest fluxes of cosmic rays."
    Back in 2014, Schwadron et al used a leading model of solar activity to predict how bad cosmic rays would become during the next Solar Minimum, now expected in 2019-2020. "Our previous work suggested a ~ 20% increase of dose rates from one solar minimum to the next," says Schwadron. "In fact, we now see that actual dose rates observed by CRaTER in the last 4 years exceed the predictions by ~ 10%, showing that the radiation environment is worsening even more rapidly than we expected." In this plot bright green data points show the recent excess:
    The data Schwadron et al have been analyzing come from CRaTER on the LRO spacecraft in orbit around the Moon, which is point-blank exposed to any cosmic radiation the sun allows to pass. Here on Earth, we have two additional lines of defense: the magnetic field and atmosphere of our planet. Both mitigate cosmic rays.
    But even on Earth the increase is being felt. Spaceweather.com and the students of Earth to Sky Calculus have been launching space weather balloons to the stratosphere almost weekly since 2015. Sensors onboard those balloons show a 13% increase in radiation (X-rays and gamma-rays) penetrating our planet's atmosphere:
    X-rays and gamma-rays detected by these balloons are "secondary cosmic rays," produced by the crash of primary cosmic rays into Earth's upper atmosphere. They trace radiation percolating down toward our planet's surface. The energy range of the sensors, 10 keV to 20 MeV, is similar to that of medical X-ray machines and airport security scanners.
    How does this affect us? Cosmic rays penetrate commercial airlines, dosing passengers and flight crews so much that pilots are classified by the International Commission on Radiological Protection as occupational radiation workers. Some research shows that cosmic rays can seed clouds and trigger lightning, potentially altering weather and climate. Furthermore, there are studies ( #1, #2, #3, #4) linking cosmic rays with cardiac arrhythmias in the general population.
    Cosmic rays will intensify even more in the years ahead as the sun plunges toward what may be the deepest Solar Minimum in more than a century. Stay tuned for updates.
  2. hill
    8,779
    Too soon to guess if this may be the result of some multi-1000 yr cycle?
    (sigh) seems like the trailing end us us baby boomers was a good time to be born, & now enentering old age. Too young for Vietnam & too old to get majorly affected by ozone depletion & cosmic rays.
  3. bwilson4web
    16,172
    I appreciate we'll see more cosmic rays. Just I'm curious about the dosage change?
    Are we looking at sterilization or just an incremental amount that joins radon or granite background radiation?
    Thanks,
  4. wjtracy
    11,365
    3,608
    Northern VA (NoVA)
    How does Elon Musk plan to handle this issue on Mars?
  5. Trollbait
    12,483
    Build underground would be my plan.
  6. hill
    8,779
    But wait, underground is where the radon gas seaps from.
    Kidding aside - this video uses bananas of all things - to illustrate radiation
    It even briefly discuss hi flying commercial pilots which @wjtracy mentioned in the op.
    #6 hill, Mar 6, 2018
  7. bwilson4web
    16,172
    Send old people like me and wait for the dirty, bug infested Space Tesla to arrive.
  8. DavidA
    2,344
    1,820
    Chicago western burbs
    Won't the cosmic rays just irradiate the Earthly space bugs on Spaceman's car in the meantime? The underground Mars habitat, if built, will no doubt have a gigantic SpaceX/Tesla logo roof (more "free" advertising). I'd worry that the big logo might attract the Spaceman's car (thinking it was going home), and crash into it at very high speeds. Those cars do have a summon and homing feature.
  9. tochatihu
    tochatihu Senior Member
    9,741
    3,758
    Kunming Yunnan China
    2001 Prius
    When sunspots are few, sun's magnetic field shields earth less from charged particles from elsewhere. Situation occurs every 11 years. Stayed low from years 1640-1720 approx. During which time life on earth survived though climate was altered (with probable volcanic assistance).
    Now we do more technical things and sometimes exit Van Allen belts, so such charged particles could be more of a bother.
    Contrariwise, when sunspots are many, sun shoots out more charged particles in directional though random ways. So, any target is unlikely to get hit, but if hit, could get hit very hard. See Carrington event.
    So, you get what you get.
  10. wjtracy
    11,365
    3,608
    Northern VA (NoVA)
    Do you think that Telsa might get a flat tire in space?
  11. DavidA
    2,344
    1,820
    Hard to say. If there was air in the tires, then there isn't any now. So that's maybe a yes. But "flat" only refers to the bottom of a tire with weight bearing down on them, so, no.
  12. hill
    8,779
    pressure change? Vacuum?
    Maybe that's why Costco use is pure nitrogen. Planning ahead for Mars
  13. tochatihu
    9,741
    3,758
    2001 Prius
    First post mentioned Dr. Schwadron. Would clearly know whether GCR dose is lower when moon is in earth's magnetotail.
    I presume it is so, but not sure.
  14. tochatihu
    9,741
    3,758
    2001 Prius
  15. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    This would explain why Godzilla has been getting so frisky lately. The more you know...
