I Hate Texters
Discussion in 'Prime Main Forum (2017-2022)' started by HPrimeAdvanced, Feb 22, 2018.
  1. Insighter
    Insighter Active Member
    409
    287
    SoCal
    I couldn't agree more. I can't see buying an electric car right now.
    I haven't visited many paid charging stations here in San Diego, but I get the impression they are usually around $.54/kW. It's my understanding from posts I've read in these forums that it takes about 6.5 kW to fully charge the Prime, which gets you about 25 miles of driving. Even at $.30/kW, you'd be paying $1.95 to go 25 miles, right? But you could go over 50 miles on $3.20 worth of gas, so aren't you paying more to use electricity? Are my numbers off?
    HPrimeAdvanced likes this.
  2. bwilson4web
    16,192
    Select the car of choice from www.fueleconomy,gov:
    • Get the kWh/100 mi, A
    • Get the Gal/100 mi, B
    • Look up local electrical rate $/kWh, C
    • Solve: C * (A/B) = local cost of parity gasoline
    So lets take an example of plugin hybrids in Huntsville AL where the my last bill was $0.091 per kWh, C:
    • 2014 BMW i3-REx: $0.91 * ( 29 / 2.6 ) = $1.02 / gal (premium)
    • 2018 Pacifica: $0.091 * ( 40 / 3.1 ) = $1.17 / gal (regular)
    • 2018 Chevy Volt: $0.091 * ( 31 / 2.4 ) = $1.18 / gal (regular)
    • 2017 Prius Prime: $0.091 * ( 25 / 1.9 ) = $1.20 / gal (regular)
    • 2018 Ioniq plugin hybrid: $0.091 * ( 28 / 1.9 ) = $1.34 / gal (regular)
    When gasoline is cheaper than these prices, run the car on gas. Above these values, electricity is cheaper in Huntsville AL.
    #122 bwilson4web, Mar 10, 2018
    HPrimeAdvanced, benagi and Insighter like this.
  3. Insighter
    409
    287
    SoCal
    If I read that right, it seems like those numbers are about in line with what I was saying. If you have to pay $.30 per kW (over three times what you're paying), the equivalent price of gas would be over $3.60 per gallon, so gas would be cheaper in that instance.
    25 kWh per 100 miles sounds about right from what I've been reading. It would take about 4 full charges to go 100 miles, and each charge is about 6.5 kWh. You'd need electricity to cost about $.25 or less per kWh to make sense with gas prices what they are here in California.
    I think you have some exceptionally low electricity rates. You're not part of the TVA (Tennessee Valley Authority) there, are you?
  4. bwilson4web
    16,192
    Yes but I'd recommend using U.S. Energy Information Administration (EIA).
    We aren't the cheapest but we do OK.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    No I'm not. Read again. "I use the nav system most of the time because of the law ...".
  6. Insighter
    409
    287
    SoCal
    I read that, but you said "most of the time." I am not, of course, referring to the times you are following the law. But, the rest of the time, you are risking a ticket.
  7. Lee Jay
    5,850
    4,036
    That's an assumption. A wrong one. The rest of the time I'm on private roads.
  8. Insighter
    409
    287
    SoCal
    Really? You travel so far on private roads that you need to refer to your phone for guidance?
  9. dubit
    dubit Senior Member
    850
    538
    Indiana
    2016 Prius c
    That just gets me that it's functionality is so impaired like that on Android phones. For the life of me I can't understand why they would make something so absolutely useless. It's a simple "checkbox" in the settings on my phone that tells it to utilize Cortana and any other voice activated app to function if connected via "Bluetooth". Seems they could do that too.. or at least one would think.
    If not connected via Bluetooth to something, then my phone also must be unlocked in order to use Cortana or anything else.
  10. dubit
    dubit Senior Member
    850
    538
    Indiana
    2016 Prius c
    Big difference between you and him. He's from Colorado, not SoCal. Even done that myself here...
    Insighter likes this.
  11. Lee Jay
    5,850
    4,036
    No, I use it to figure out when I get off the private roads (work and my flying club) what route to take. It's much easier to look at the map when I hold it up kind of like the HUD rather than have it down on the charging pad and it's safer than a fixed mount because I can hold it in an unimportant (for that moment) area of my field of view.
  12. Lee Jay
    5,850
    4,036
    They do but my understanding is that the car will only send Bluetooth audio requests to the phone if the phone is an Apple device. At least, I can't make the car do it.
  13. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    No. The details, it's the details! I get 32-35 miles of range on a full charge; that's consistent. At $0.30/kW, with gasoline at $3.20/gallon, I'm breaking even. My car goes an average of 5.5 miles per Kilowatt (kW), so for $3.20 it can go about 58 miles on publicly available electricity. My home L2 (level 2, 220v) charger costs about $0.15/kW to charge, so it's cheaper than gas at the current price. Our gas prices are going up slowly over here, so electric should become more attractive yet.
    AChoiredTaste.com
  14. Lee Jay
    5,850
    4,036
    The unit of energy is "kWh" - kilowatt hour. Saying "my car goes an average of 5.5 miles per Kilowatt" is like saying "my car goes an average of 50 miles per horsepower".
    Insighter and HPrimeAdvanced like this.
  15. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    So I'm sloppy!!
    AChoiredTaste.com
  16. William Redoubt
    William Redoubt Senior Member
    1,228
    1,172
    Coronado Island, California
    Except for Waze. We need Waze to watch for the PoPo.
    pilotgrrl likes this.
  17. Insighter
    409
    287
    SoCal
    Wow, 32-35 consistently? You must drive very carefully. So the numbers do pencil out for you, but what about the charging time? Doesn't this leave you sitting at public chargers hours at a time with not much to do?
  18. Insighter
    409
    287
    SoCal
    So we've found one small area where my iPhone offers increased functionality and compatibility. I'll take it!
  19. Insighter
    409
    287
    SoCal
    Dubit is right. I should have looked at the city you're in (I actually attended Westminster High School for a semester). Living where I do (Southern California), it's hard to remember that there are places where private roads are, I would imagine, much more common. The only private roads I ever drive on here are in my neighborhood.
  20. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Yup!! And yeah, where do you think the Crippled Snail came from. I now drive as much as possible on surface streets, and have located a lot of charge stations critical to staying on electric. Hey, I don't have a girlfriend or wife just Yewee the cat, so I can play these dumb "rally" games. It's "racing" for efficiency instead of speed, (and no speeding tickets!). Occasionally, I'll let 'er rip against an SUV or other vehicle, which almost never know I'm gunning for them because of the Stealthy Electric. I keep 'er in EV/POWER mode, so the car feels nervous and fun to drive, especially through the hills, with twisty bits in places like Brea. I've made no "Long Trips" to Bakersfield or Lancaster for a while, so I'm maximizing the Prime's advantages. I've passed 3800 miles on this gas tank; last filled up in December, last year, and still have 323 miles of gasoline range left! I love my Prime!
    AChoiredTaste.com
    benagi, pilotgrrl and Insighter like this.
