GPS MPH vs Dash MPH
Discussion in 'Prime Technical Discussion' started by MikailSJ, Mar 14, 2018.
  1. MikailSJ
    MikailSJ Member
    35
    27
    I purchased 2x prius prime plus models (don't ask lol). I've noticed with both models, the MPH is overestimated on the dash by 2-3 miles in both cars in comparison to those radar equipped signs on the side of the road to slow you down and my GPS. Anyone else notice this? Guessing my MPG is way off as well
    priuscatprimeguy likes this.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Yup, I noticed that too. If I set my cruise control to 36 MPH the radar equipped sign a block from where I live will show 35 MPH.:cool:
  3. MikailSJ
    MikailSJ Member
    35
    27
    Right the difference is only 1 MPH or so at lower speeds, I get the 3 MPH difference consistently at 70-75.
  4. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    Yep, My Prime is like that and so was my Gen 3 Prius. I always thought it was my 17" tires on the Gen 3, but I guess not now...
  5. Mendel Leisk
    41,824
    mph display is off by legislation: they don't want people going faster than posted speed limits. I guess that went out the window...
    mpg display is off due to Toyota compulsion to BS, and not connected to above.
  6. MikailSJ
    MikailSJ Member
    35
    27
    What legislation is this?
  7. fuzzy1
    10,588
    All of the EU, for one. I've heard that certain lower level US jurisdictions have similar laws. Regardless, this is essentially industry standard practice.
    The odometers do not have the same error, in fact class action product liability lawsuits over warranty fraud have pushed some makers to make their odometers intentionally under-read by 1-2%.
    The internal computers know the true speed more accurately. You can see this with a ScanGauge-II or any other OBDII engine monitor. It is the speedometer display that is intentionally fudged to read slightly high in North America, significantly higher in the EU.
    ... but at least that takes away a driver excuse.
  8. Mendel Leisk
    41,824
  9. ct89
    ct89 Active Member
    323
    266
    New England
    If it really bothers you, upsizing the tires is a simple way to "correct". A 205/65/15 tire would fit nicely on your rims, it is 2% larger so actual MPH would be 2% faster than currently reported with your stock tires. You will also see the reported distance and MPG drop by 2% for the same trip.
    I actually did this with my 2004 prius...Ran with 195/65/15 tires vs. the stock 185/65/15 and felt everything (MPG, MPH, etc.) was more accurate. 2% is a pretty small number but if it makes you feel better, it is an option.
    Wuzki and MikailSJ like this.
  10. Trollbait
    12,653
    Doing this to correct the speedometer display will result in the odometer now being off. Which could be construed as fraud.
  11. Mendel Leisk
    41,824
    It does seem tail wagging the dog.
    Funny, "solutions" of this sort come up so often, I've just given up commenting.
  12. bisco
    52,286
    there was another member here who was going to start a class action lawsuit because the odometer was reaching warranty before the car. i wonder how that is coming along.
  13. Wuzki
    Wuzki Member
    101
    34
    los angeles
    Manufacturing done this on a purpose, they want to make you think you are driving faster than what you actually is. BMW, Mercedes they have the range of 5-15 mph faster than the actual mph.
  14. Wuzki
    Wuzki Member
    101
    34
    los angeles
    :eek:
    How can this become a lawsuit? Lol...
  15. Trollbait
    12,653
    A couple of such lawsuits have already won against the manufacturer.
    bisco's wording could be a little confusing. The complaint was that the odometers were reading faster, cutting the cars off from warranty coverage before they had truly hit the mileage limit.
  16. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    My 16 and now 17 came with 195/65-15 tires 25" outside circumfrence which gives the correct odometer reading, Toyota was undersizing the 15" wheels and is still undersizing the 17" wheels.
    My wife's BMW X1 was the base model and the wheels were undersized, so without a gps you were always holding up traffic;)
  17. MikailSJ
    MikailSJ Member
    35
    27
    This must have occurred since 2003. My old Highlander's MPH is correct
  18. bisco
    52,286
    funny thing is, some government agency doesn't want you speeding, but the cops could care less.
  19. Mendel Leisk
    41,824
    Just editorial: I think you mean couldn't care less?
  20. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    On bmw you can code it so that it shows the correct speed
