15 or 17 inch wheels?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 4est, Mar 15, 2018.
  1. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    What should I choose?
    The 15 inch wheels are lighter, but they have plastic covers
    The 17 inch *should* look better, but they are havier
  2. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    It's just stupid to use lower-profile tires. Faster wear, more expensive, more prone to sidewall damage, harsher ride, little to no handling improvement. Just for appearance?
    Salamander_King and mrlebop like this.
  3. Mendel Leisk
    41,894
    Since you inadvertantly posted in PIP forum, that model has a sweet 15" rim. I've got the 17" OEM, and acquired a set of the 15" PIP rims, will likely end up using them on snow tires. Anyway, playing around in Photoshop:
    Stock 17" rims:
    PIP 15" rims:
    And close up of the actual PIP rims I've acquired, complete with Shiba:
    My take, they make the car look a little more "businesslike", work pretty good.
  4. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    You do see the "plug in hybrid" inscription on the car, right?
    And the blue color that is (I think) unique to the plug in (pip). :)
    The 17 inch should provide better stability though
    That is if you drive the car close to the limits, which is unusual for a prius driver
    mrlebop and Mendel Leisk like this.
  5. Mendel Leisk
    41,894
    Oh sorry, gotcha.
    There's one corner we take, year 'round. In winter it's with 195/65R15 Michelin X-Ice on steel Corolla rims (our snow tires), and in summer it's with Michelin Pilot HX MXM4 215/45R17 on OEM third gen 17" rims (as you've pictured above). It's a fairly tight curve and I take it around 40 kmh with both setups, and really can't tell any difference.
    Ajrob671 likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    It's not apparent in your picture. You can see it if you zoom in all the way, and know what to look for.;)
    So, the European PiP didn't get the cool looking wheels? That's a shame. Mine are like the ones @Mendel Leisk bought.
    I would not want the 17" wheels because I can't see spending extra money on wheels just so I can spend extra money on gas.
  7. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    In Europe the only wheels for the PIP were the black 15" alloys with hubcaps like the OP's picture. I took off the hubcaps and got some OEM centre caps (think they're for a Yaris or something, but they fit) - I think the black wheels go well with my white (pearlescent) car, not sure how well it would work with the blue.
  8. Mendel Leisk
    41,894
    They should have put those (US) PIP rims on all 3rd gen Prius with 15" rims. :mad:
    And in 2012 they changed the rim under the god awful plastic wheel cover, from semi-nice silver to black. :confused:
    So here we are. :rolleyes:
    jerrymildred likes this.
  9. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Why stop at 17", why not 18" or 19" with spinners, and get some struts that drop the car, be sure to toe the tires out as you drop the car.
    Or, get the best possible mileage per gallon with the 15" wheels.
    Fish or cut bait!
  10. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    haha, nice one Lufcifer!
    The thing is, the "old" (although same year) Prius XW30 that the blue Prius XW35 is replacing came with the 17" wheels (with winter tires ?!?!), I purchased summer tires (+other 15" wheels+winter tires).
    So now I have both 15 and 17 wheels, so cost is not important, as I won't replace tires for either of them
    The only factors are: looks, feel and confort
    I would have decided for the 15" if they were normal silver wheels, instead of black ?!?! with plastic ?!?! covers
    The good thing is you can't really tell they have plastic covers, as you usually can with steel rims that are visible under their covers
  11. QuantumFireball
    420
    269
    Ireland
    The 17" wheels should improve handling slightly, but won't help you in terms of ride quality or efficiency.
    4est likes this.
  12. Giuliah Luciano
    Giuliah Luciano New Member
    Panorama city
    2014 Prius c
    Does anyone know is 17 inch fits on Prius c which is 15?
  13. Mendel Leisk
    41,894
    Just curious, that's Panorama City, a district in Los Angeles, in the United States?
    You could probably do 17" on a c, if you keep the Outside Diameter about the same. Look on TireRack: if you enter your vehicle they'll show compatible tires/wheels, in stock or other sizes.
  14. Eodguy
    Eodguy Junior Member
    Seattle
    I had 15" wheels on my Prius and when to 17" wheels, 195/65/15 vs 215/45/17 they are very close to the same size other than the width and the sidewall. I believe the ride quality is vastly improved, cornering is much better and I hardly notice any loose of efficiency. I avg 60 mpg plus on each fill up.
    Teacake and QuantumFireball like this.
  15. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    I went with the 15" wheels
    They are much lighter, at least the plugin version
  16. Godzuki
    Godzuki Active Member
    133
    114
    Bay Area, CA
    2015 Prius Plug-in
    johnix, Steph1972, mrlebop and 2 others like this.
  17. So_Jah_Seh
    So_Jah_Seh New Member
    SoCal
    2015 Prius c
    I read this thread and decided to go with DR-33 17" with Bridgestone Ecopia Plus 215/65/17, MPG took a 2-7 hit but I still am happy with my purchase
    RMB likes this.
  18. Karl Goh
    Karl Goh Junior Member
    31
    New Zealand
    i-Tech
    Wanting to swap my Stock gen1 Plug in to Bridgestone Eco Forme wheels.
    i think it looks slightly better than OEM 15" although no aero hub caps(dont know how effective they were)
    Hope i didn't make the wrong choice for better comfort, mpg and looks
  19. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Any pic of the wheel? I was thinking of pip OEM 15 inch alloy for my PRIME, but it has slightly bigger offset 6Jx15 ET45 and they are quite expensive even used.
  20. Karl Goh
    31
    New Zealand
    i-Tech
    BRIDGESTONE (ブリヂストン) ECO FORME (エコフォルム) SE-10 14×4.5J(+46)PCD100-4H シルバー BRIDGESTONE (ブリヂストン) BLIZZAK (ブリザック) VRX 165/70R14 中古 スタッドレス タイヤホイール 4本 [14taw104]
    If this doesn't work, google Bridgestone Eco Forme Se-10
