Bizarre Problem with Reading Texts and Bluetooth Audio
Discussion in 'Prius v Audio and Electronics' started by vsavatar, Aug 28, 2015.
  1. vsavatar
    vsavatar Junior Member
    Livonia, MI
    2015 Prius v wagon
    I don't know if any of you have experienced this before, but there's a problem whereby whenever you have the car read you an incoming text message, whatever song happens to be playing restarts from the beginning. At least this is happening on my Note 3. I should note that this happens with EVERY SUBSEQUENT text message as well. I can only listen to the same intro to the same song so many times before going insane, and if I'm in the middle of an hour long mix set and don't happen to see the time index before it happens, I have a hard time of figuring out where I left off. Has anyone had this problem? If so, were you able to fix it? Any ideas on how I might fix it?
    Xaz likes this.
  2. Xaz
    Xaz New Member
    2017 Prius v wagon
    Did you ever figure out how to fix the problem because I have the same issue with my prius v and it's a 2017
