ABS light comes on, wheels lock, and then goes off
Discussion in 'Gen 2 Prius Main Forum' started by prius_noob, Mar 19, 2018.
  1. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    I've sometimes had it (Typically in bad weather), that the ABS light is starting to flash, and my wheels are starting to lock
    I've used cheap winter tyres (new) Could this be why I'm getting this?
  2. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    Could be.
    Do you think the term "lock" could be an exaggeration? Could slip be a better word?
    If so, it is a normal thing particularly worse/better depending on tire choice.
    SFO likes this.
