Wiper blade replacement '16 Prius Three.
Discussion in 'Gen 4 Prius Main Forum' started by DonJuan1943, Mar 17, 2018.
  1. DonJuan1943
    DonJuan1943 Member
    64
    53
    Northern Illinois
    Most aftermarkets show replacements for 2010-2015; then 2017 and 2018. ...But, none for the 2016. I am interested in a DEFINITIVE solution to the replacement situation for the 2016. I am on my third Prius, and most of the repairs/replacements on the earlier Priuses were standardized to "almost aircraft precision". I need help with this one. My Toyota personnel cannot provide a meaningful answer.
  2. Mendel Leisk
    41,923
    Do you mean your dealership parts department doesn't have replacement wiper inserts?
    This page has info, I believe "refills" are the rubber-only bits:
    Windshield Wipers | Toyota Parts
  3. Prodigyplace
    12,682
    11,833
    Central Virginia
    RCO likes this.
  4. Mendel Leisk
    41,923
    Our 2010's blades are still champion. That said, it's garage stored, and we don't get out much.
  5. MichelleStone
    MichelleStone Senior Member
    549
    818
    Mariposa, CA
    When I had my 2016 car in for it's free biannual service, I asked them to put in new wiper blades. They said they didn't have them in stock. I was pretty surprised at that.
    pilotgrrl and RCO like this.
  6. DonJuan1943
    DonJuan1943 Member
    64
    53
    Northern Illinois
    Thank you for your responses. I am too lazy for the disassembly of the existing blade and replacing the rubber. I am still looking for a "blade replacement" for the driver's position.
  7. Prodigyplace
    12,682
    11,833
    Central Virginia
    I used my previous links to find it. you really need to learn how to navigate websites.
    Here is the link for the blade.
    2016 Toyota Prius Parts - metrotoyotapartsnow.com
    RCO likes this.
  8. Mendel Leisk
    41,923
    Do your bit for saving the environment, and a few bucks, learn how to change just the rubber bits.
    Also, it could be there's nothing wrong with your current blades, the windshield is just gumming up, needs a clean. Wipe down the blades too. Get a heavy-duty automotive glass cleaner.
    RCO and Prodigyplace like this.
  9. Prodigyplace
    12,682
    11,833
    Central Virginia
    They may want you to travel & do it for them while they watch. :(
  10. Mendel Leisk
    41,923
    Whatever it takes...:whistle:
  11. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    Yes, refills are the rubber only pieces. When I too my car in for its penultimate Toyota Care, they were out of the wiper blade inserts. Mine were end of life, I have no garage or covered parking (unless I park under a tree, which might be a bad idea).
    First take off the "cap" at the base of the rear wiper housing.
    Slide out the old rubber inserts and keep the metal "spines".
    Open the package containing the new inserts, then slide the spines into the inserts. This part is a little tricky.
    Slide the whole assembly (inserts + spines) carefully back into the channel of the wiper housing.
    Replace the cap at the bottom of the rear wiper housing and you're done.
    I watched the service writer at Toyota of Denton do this for me last week.
    Sorry I don't have pictures, I was too busy watching the procedure.
    RCO likes this.
  12. Prodigyplace
    12,682
    11,833
    Central Virginia
    Perhaps they should go to the dealer too.
  13. Mendel Leisk
    41,923
    I see the 4th gen Owner's Manual has decently detailed instruction on how to get the blades off the arm, which means you can replace the rubber bits in more comfortable surroundings, especially in winter. Third gen manual had pretty much nothing on the subject, not too good, considering it's 600 plus pages. Anyway:
    One caution if your remove the blades from the arm, be VERY careful about not releasing the free arm, thwack into the windshield. Maybe put something good and thick down, beforehand.
    RCO and pilotgrrl like this.
  14. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Not sure if it happens in other places, but here, if they're not busy, the Auto Parts store guys will often install them for you.
  15. pilotgrrl
    891
    1,797
    Chicagoan in TX
    The inserts for the rear wiper aren't available at auto parts stores in the US yet.
    In theory, Bosch Icon blades are supposed to fit, according to the guy at O'Reilly's, but I have my doubts. They didn't fit when the guy at Advance Auto Parts tried to put them on.
    RCO, bbald123 and Prodigyplace like this.
