stupid question about folding down the rear seats
Discussion in 'Gen 3 Prius Main Forum' started by southjerseycraig, Mar 18, 2018.
  1. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    I only occasionally fold down the rear seats in my 2010 Prius II (generation III). I tried recently and couldn't make it work.
    My understanding is that the first step is to lift out the metal strip running from side to side. I thought I remembered that the best way to do this is to lift straight up with an underhand grip. Nothing happened. Is there something on the strip I have to adjust before I can lift the metal piece out?
    I did a google search, and Toyota's videos do not even mention that metal strip, which surprised me. Can it be that the strip stays there even when the rear seats are folded down?
    Thanks and sorry for not knowing thisl
  2. frodoz737
    frodoz737 Top Wrench
    4,721
    2,517
    33
    Folding down the rear seat back? Just push down the button outboard of each head rest and lean it forward. The cargo cover just pops out straight up.
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    I find I have to first remove the headrests, then push the button and fold the seat-back. The headrest fits on the floor with the rods up, and they wedge between the seat-back and the front seat-back, keeping the headrest in place so it won't become a missile in an accident. The cargo cover can stay in place or can be stored under the hatch floor. There are notches on each side for it to sit in.
    southjerseycraig likes this.
  4. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Perhaps this changed after 2012, but in both my 2013 and 2014 Gen 3s, the headrests fold 90 degrees forward, getting out of the way so they will clear the back of the front seats when the seat back is lowered. Push the headrest release button, raise the headrest and fold it forward. It does not need to be removed.
    Robert Holt, jerrymildred and Burna J like this.
  5. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    What are the metal strips? The lower part of the headrests?
  6. Mendel Leisk
    41,906
    By metal strip do you mean the tonneau cover:
    You don't have to remove that, though if you're going to put bulky items in, then you would. You just firmly tap up on it's underside, pop it out of the recess, both ends, then angle and lift it out.
    Then there's buttons on the seat back shoulders, you need to kind of push them forward, like sliders, and the seat back releases, can rock forward. If the front seats are push fairly far back, the back seat head rests may run into them, so just push the front seats forward a bit.
  7. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Please remember to carefully ease the left and right side rear seatbelts out of their guides on the shoulders of the seats before folding the seat backs forward, and then place the belts over to the side of the car and avoid tangling them when you fold the seat back down. Getting a crease in the seatbelt retractor spool gizmo may jam it, and it is a bear to get to, I think.
  8. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    And the tonneau cover has a neat storage space beneath the rear deck lid. See your owner's manual...
  9. southjerseycraig
    438
    107
    Cherry Hill, NJ
    I at least knew that, but thanks for the reminder!
