Costco Velox rims
Discussion in 'Prime Accessories and Modifications' started by Rashid K, Mar 7, 2018.
  1. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    Because when they're black, you can do fun stuff like this...
  2. DTS
    DTS Junior Member
    Bayarea
    Can you post a pic with those on your car ?
  3. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    I was curious about the all important wheel weight on the 17x7.5" Velox wheels, so I contacted them for the info, here's their response.
    "Thank you for your interest in Velox wheels.
    The Apex 17x7.5 wheel weighs 18.5 lbs each for the Prius Prime.
    If you have any further questions please feel free to contact us at 1-877-999-4335 during our normal business hours."
    I personally believe (IMO) that 18.5 lbs is a bit high for wheel weight on a Prius Prime, by the time someone installs the
    typical 20 lbs to 21 lbs tire with the needed tpms & wheel weights for balancing, the wheel/tire combo will top out at roughly
    39 to 40+ lbs.
    Rob43
    #23 Rob43, Mar 21, 2018
  4. SaraBBrown94
    234
    263
    Pittsburgh PA
    I posted a pic in the comment before yours but here's another. :) 1521668754861.jpg
  5. DTS
    DTS Junior Member
    Bayarea
  6. SaraBBrown94
    234
    263
    Pittsburgh PA
  7. Mendel Leisk
    41,908
    Yeah but how low can you go? FWIW, the 2012~2015 PIP 15" rims are 18.5 also. I've weighed one.
  8. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Well, in the cheap category the 17x7" Maxxim Winner at ~$105 shipped and it weighs in at 17.0 lbs. (My current favorite)
    In the expensive "money is no object" category, $200 to $500 per wheel buys you a 17x7" to 17x8" at 14.0 lbs to 15.9 lbs per wheel. My 2 favorites are the $229 17x7.5" Enkei RPF1 at 15.2 lbs & the $200 17x7" Kosei KR4 at 14.0 lbs; though both would require a ~10mm spacer.
    Rob43
