2 year Update 2016 Gen 4 Prius Video
Discussion in 'Gen 4 Prius Main Forum' started by JimmyPri, Mar 20, 2018.
  1. JimmyPri
    JimmyPri Active Member
    201
    245
    Hilo, Hawaii
    I have a new video about my 2016 Prius Gen 4 update after 2 years
    krmcg, Mendel Leisk, pjm877 and 6 others like this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Which sort of MPG does Hawaii use - is it standard, or the USA measure?
  3. JimmyPri
    201
    245
    Hilo, Hawaii
    It is the USA measure. Keep in Mind that the cars cumputer can be as much as two to four mpg higher than actual mpg. Even considering that, the mpg would still be over 70.
    pilotgrrl and alanclarkeau like this.
  4. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    I have a question about the rust that you experienced in one small spot on the roof. I have been to Hilo, it is quite beautiful. I know it rains a lot with high humidity year round. When I was there I put two and two together and realized that in order for a place to be that lush and beautiful that it has to have a lot of rain! :) I am wondering is your car parked outside most of the time? Does it spend a lot of time with water sitting on the roof? Just wondering if it was somewhat extreme conditions that led to some corrosion after just two years. I realize it was a very small area that was affected.
  5. alanclarkeau
    7,045
    7,593
    Yes - and which part of the roof was affected, thanks.
  6. JimmyPri
    201
    245
    Hilo, Hawaii
    It does rain a lot and is humid but not as humid as Florida. It is parked outside all the time but on a slight angle down. Where the water does collect and stay longer is on the hatch lid spoiler area. And that isn't showing signs of rust. The cars are shipped here from Honolulu on another island. They sometimes are just put on the deck of a barge rather than in a container. And in that case some people speculate that cars often get ocean salt water spray on them. And if the dealer lets the cars sit for a long time without washing that could start some corrosion.
    RCO, pilotgrrl and Since2002 like this.
  7. Since2002
    936
    1,098
    Duluth, GA
    Thanks!
  8. JimmyPri
    201
    245
    Hilo, Hawaii
    The section of the roof was the rear left area.
  9. alanclarkeau
    7,045
    7,593
    The hatch lid, as far as I know is Aluminium, not sure what the spoiler is made of - it may be a non-metallic. Both are non-magnetic.
  10. farmecologist
    farmecologist Senior Member
    1,960
    1,800
    Southern MN
    Thanks Jimmy! Always like your videos.
    Nice average MPG! I'm assuming not much highway use?
  11. JimmyPri
    201
    245
    Hilo, Hawaii
    Thanks. And thanks for watching. You are correct that I do very little highway driving nornally and even less in the last several months.
    farmecologist likes this.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Nice video, Jimmy. Thanks.
    As to the rust, we lived for nine years on a small Caribbean island. Rust was a non-stop struggle there costing hundreds of dollars a year in body shop work. It didn't need to get splashed with salt water (although that's way worse). There's enough salt just in the air to make lots of rust.
    RCO likes this.
  13. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    Great video! My 2016 is coming up on 2 years in June, and I've just turned over 10,200 miles.
    If I hadn't lost my Gen 2 to an accident, I'd still be driving it.
  14. Prodigyplace
    12,696
    11,840
    Central Virginia
    I thought I was skirting the low end of mileage only putting on 15,000 miles.in a year. Were you driving that few miles in your Gen 2? The Prius likes to be driven.
  15. pilotgrrl
    891
    1,797
    Chicagoan in TX
    It had 79K when I totaled it in 2016. I love driving my Prii, but not so much around here. Although I should wander around more to get familiar with the area...
  16. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    Another vote for the great video Jimmy.
    My Prius has just turned a year old and 5000 miles. I didn't know that the EV screen showed different results depending on which trip you are on, so thanks for that great tip (y)
  17. JimmyPri
    201
    245
    Hilo, Hawaii
    Thank you jerrymildred
    jerrymildred likes this.
  18. JimmyPri
    201
    245
    Hilo, Hawaii
    Thank you pilotgrrl and good luck with your continued good luck with your 2016 Prius
    pilotgrrl likes this.
  19. JimmyPri
    201
    245
    Hilo, Hawaii
    Thank you Harters.
  20. pilotgrrl
    891
    1,797
    Chicagoan in TX
    You're welcome, JimmyPri, and I wish you good health and many more happy miles in your 2016 Prius.
    RCO and Since2002 like this.
