Left my 2017 Prius running overnight
Discussion in 'Gen 4 Prius Main Forum' started by just24, May 28, 2017.
  1. just24
    just24 New Member
    los angeles
    it was on "ready"... any damage done? :( Car runs great still. Should I be concerned about anything
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    No - just used some fuel, and depending on where it was, could have produced some exhaust fumes to fumigate your garage.
    Someone posted that they'd done the same - for a week at the airport (with a previous Generation PRIUS).
    kithmo and RCO like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Lots of people camp in their Prius. A/C all night with barely any gas used. What kind of a dealer wouldn't brag about that when selling a car? LOL!!
    Only real danger was someone getting in your car & driving it away.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Just gas wasted and the possibility of carbon monoxide poisoning if left inside.
  5. goinskiing
    goinskiing Active Member
    202
    187
    Meridian, ID, USA
    2018 Prius Prime
    I did this once with my 2014 Prius C on a hot August afternoon in my work parking lot. It was a few year back so I don't remember specifics other than it did consume a nominal amount of fuel and that I didn't notice any ill effects on duel economy afterward.
    RCO likes this.
  6. priusman09
    priusman09 I used to be a TDI
    67
    76
    wisconsin
    It should beep at you a couple times when leaving the car running- with keys in your pocket or purse. Possibly 3 beeps if I recall correctly (for next time)
    kithmo and Prodigyplace like this.
  7. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    Apparently you left it someplace where you don't lock the door. It would have beeped at you for forgetting to turn it off.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Your anecdote is welcome, but near in mind that your car is a Prius C, different from a Prius hatchback. (y)
  9. Mendel Leisk
    41,814
    Was it in Park or Drive?
    Just thinking, 'cus I rarely if ever hit the Park button, just shut it down and apply parking brake. But if I missed step one, it'd likely be sitting in Drive. I kinda miss the old day, when you put the keys in the ignition, and you WEREN'T getting them back, till you pushed the shifter to Park AND shut the car down.
  10. goinskiing
    202
    187
    Meridian, ID, USA
    2018 Prius Prime
    Right, but the idea is largely the same. I actually now have the hatchback and noticed it will give me more warning than the C did. I was just mentioning that regardless of warning, the hatchback and the C will respond largely the same way when unattended.
    RCO likes this.
  11. alanclarkeau
    7,045
    7,593
    You can only lock the Gen 4 with the physical key. If I'm leaving mine for a few minutes (rare, but has happened), I power OFF, then back ON - otherwise the DRLs are shining, alerting anyone to it running.
  12. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    As I recall, the car will complain loudly, including large yellow triangles on the dash, the second you unlatch the door with the car still in Drive. In Park, it will only Beep upon closing the door.
    RCO, Mendel Leisk and alanclarkeau like this.
