Car Scanner for iOS - free OBD2 app with custom PIDs support
Discussion in 'OBDII iPhone App' started by 0vZ, Feb 1, 2018.
  1. 0vZ
    0vZ New Member
    Russia
    Hi guys!
    I'm developer of Car Scanner app for iOS, Android and Windows Phone.
    Just if you're interested, there is a built-in connection profile with Prius pids support.
    Sorry, I can't post a link here, but you can find it in the AppStore using "car scanner elm obd2" search request.
    If you have any question, or if you find a bug, or if you want to please tell me.
    PS. This app is free.
    tangerino, walterm and SFO like this.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,441
    3,332
    Madison, Wisconsin
    #2 ericbecky, Feb 1, 2018
    SFO likes this.
  3. SHDL
    SHDL Junior Member
    43
    SW Portland Area
    Thanks for letting us know about this app. Does the app provide away to set customization settings, such as turning off the backup beep and rear seat belt warning?
  4. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    I have installed it on IOS.
    It works, but only for the engine part.
    Most hybrid values are messed up on my Prius plug-in
    I used the profile for Prius gen2, because Prius gen3 profile did not had any hybrid information
    Can I help create a profile for Prius plug-in (PIP)?
  5. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Guy is gone?? Didn't respond to questions?? From russia, anything weird happen to vehicles that were used with this app??
  6. AnthonyCaine
    AnthonyCaine New Member
    Phoenix AZ
    I'm looking at using the app on a roadtrip to monitor ATF temp, because I'll be towing about 1000lbs with my 2012 Prius. In the app there are over 20 different ATF temperature readings all labelled "ATF temperature v.#" where 1<= # <= 23, and I cannot find literature on what the differen v.#'s tell me. Please help! I'll happily pay the 6.99 for the lifetime of pro if I could just get an explanation of these sensors.
    Thanks,
    Anthony
