Questions for the wheel fitment gurus!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by alpha motoring, Mar 14, 2014.
  1. alpha motoring
    alpha motoring Junior Member
    West Covina, California
    2014 Prius Plug-in
    Hey
    I recently purchased a 2014 Toyota Prius PIP Advanced Tech, I'm already gathering my list of mods for the car. I don't want to roll or shave fenders as I plan to sell the car in 3 years.
    My main question is whether a 18x8.5 ET44 (no spacers) with a 225/40/18 would rub when dropped on coilovers or Plus springs.
    Thanks
  2. alpha motoring
    2014 Prius Plug-in
    Question answered, it'll rub.
  3. bino
    bino JDM ZVW30
    1,348
    705
    SoCal 91739
    go with 215 tires..... but ET44 is not hard to fit.....
    if you're not going very low(like I did).... that should work
    I'm running 18x8.5 ET38 with 215/40 tires.......
  4. itommytang
    itommytang Junior Member
    Roseville, California
    Question for you, what are your camber specs, and what do you think the lowest offset you could run in front and in rear with a 18x8.5 to have the rim completely flush the the fender? I like the way your car sits and I can see your wheels tuck just a little bit, but I am wanting to push the offset to the max without poke.
  5. bino
    bino JDM ZVW30
    1,348
    705
    SoCal 91739
    my front camber is -1.5.... you could either use camber bolts or you're coil overs camber plates to adjust the camber...
    my rears are on -1.....
    note:
    the rear have no camber adjustments.... to adjust the camber you could get the shims... or plates...
    regarding the lowest offset you could use...... I could not confirm that because I really haven't tried anything lower than 38 on my car.... if I remember it correctly someone here has Varrstoen(te37 rep) that are 18x9.5.... but they do poked.... (browse this tread... Gen III aftermarket wheel thread...post your pictures | PriusChat) maybe you could borrow an 18x8.5 et38 and then play around with spacers to see what offset you would like to run on your car....
  6. itommytang
    could you take a picture of your wheels with like a measuring tape to show how much space is left to the fender please? that would give me an idea as to how much offset I would have to play with.
  7. bino
    bino JDM ZVW30
    1,348
    705
    SoCal 91739
    I could probably do that... but it would be next weekend.... I'm pretty busy right now till next Friday....
  8. toyopri808
    toyopri808 Active Member
    226
    116
    my wheel setup is 18x8.5 +35 square with 215/40 conti DWS on coils (y)
  9. anthony ta
    anthony ta New Member
    San Diego
    Hey there! I’m new to this forum and I was looking for a new wheel setup... this has definitely caught my eye and I was wondering if you or someone else could please tell me what kind of wheels these are?:) Thank you so much!!
    Burna J likes this.
  10. Johnsk93
    Johnsk93 Senior Member
    212
    1,055
    San Jose, CA
  11. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    Never understood why people make such a big deal on rolling fenders
    James Powers likes this.
  12. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    Right? You get it done right, you cant even tell it was done at all..
    Burna J likes this.
