2007 Prius base, 62K miles P0A80, P3016, C1259, C1310
Discussion in 'Gen 2 Prius Technical Discussion' started by GKinslow, Mar 24, 2018.
  1. GKinslow
    GKinslow Junior Member
    San Antonio
    No sir, I'm not a lawyer. I just play one on TV.:)
    I'm just a retired soldier, probably older than you, truth be told. No pull. Our son is a lawyer, though. He gave me a snowball's chance, and that was his only advice. He was surprised at the outcome.
    But a few things I've picked up over the years have served me well:
    Deal with a widely respected company that values its reputation.
    Organize your concerns and list them before contacting anyone.
    Present your concerns in a firm, but respectful manner.
    Avoid being confrontational (the most difficult thing to do).
    Don't assume your counterpart is out to screw you. If he is, that becomes evident fairly quickly.
    Assume your counterpart wants to do the right thing and avoid conflict. It's just good for business.
    Take notes. Now, while events are fresh. Not later.
    Take names and phone numbers.
    Be respectful of your counterpart's position.
    Recognize your first, maybe second point of contact may not be in a position to make a decision and finds "no" is the easiest response.
    Find the person who is in the position to make a decision without fear of repercussions from superiors.
    Be prepared to compromise.
    Be prepared to elevate your concern if necessary, advise your counterpart of same, and follow through without delay.
    Take legal action only as a last resort, and only if you're firmly convinced in the legitimacy of your concern.
    Be patient.
    Be prepared to lose and move on or get nasty and deal with possible repercussions.
    If you're doing face to face, dress appropriately. Business attire if necessary. It wordlessly communicates you're serious.
    Just treat the other guy the same way you would want to be treated.
    Most of the time, this approach earns positive results. Not always. And never if you're dealing with Joe Schmoe's EZCredit Curbside Auto Sales.
    And sometimes I'll embark on something doubtful because I just don't know any better.
    These notes aren't in any particular order. If they help someone, I'm happy. Just a small payback for the wisdom this newbie has already found in this forum.
    BTW, folks in Texas really are friendly if you give us half a chance. The PO could have blown me off, could have not answered my voice mail, but I figured I had nothing to lose by calling her and as it happens we found we have quite a lot in common. We each made a new friend.
    #41 GKinslow, Mar 27, 2018
    dolj and JC91006 like this.
  2. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    GK, allow me to go back to the advice regarding your replacement hybrid battery. There's a huge difference between a rebuilt battery and a Toyota OEM battery. And don't be swayed by the warranty on the rebuilt battery.
    There's a ton of content on this site about rebuilt batteries- but to give you a quick summary, most rebuilt ones aren't very good and the companies occasionally go out of business in the middle of the warranty.
    You have impressive negotiating skills. Make sure that you receive an OEM battery. If you don't, then update this thread and we can discuss further.
    GKinslow likes this.
  3. GKinslow
    San Antonio
    Melon, the car will be returned to service on Friday. Sterling McCall tech confirmed to me this morning the HV pack is a new Toyota OEM pack with the standard 1 year unlimited miles warranty plus a new 12V battery. I hadn't requested replacement of the failed 12V battery, as I had expected my 3rd party warranty would cover it, so I assume it's a good will gesture on the part of the dealer. Also replacing the peripherals associated with the pack (cooling fan? etc). I won't have the opportunity to actually see it, since I'm in San Antonio. I suppose I could ask the tech to take a pic but I'm not sure what I would learn from that. My 3rd party warranty is covering the installation of the new water pump but the price of the new belt is on my dime. Inverter coolant pump had been replaced under the TSB in 2011 and it has no issues. So my total out of pocket expense is the 3rd party warranty $50 copay and the cost of the new water pump belt.
  4. dolj
    dolj Senior Member
    8,428
    4,285
    Wellington, New Zealand
    If dealer installed, the warranty is 3 years, not that in reality it will make much difference.
  5. GKinslow
    San Antonio
    Thanks! That's good to know. I'm looking forward to our daughter enjoying this car for quite a while.
    #45 GKinslow, Mar 28, 2018
  6. MelonPrius
    839
    516
    Nevada
    GK, please double check the warranty with the dealer. It definitely should be a 3 year warranty because it's dealer installed. If the warranty is indeed 1 year, then investigate further.
    I'd also confirm that your 3rd party extended warranty covers the 12v. I have the Toyota Platinum warranty and it doesn't cover the 12v.
    Mavi likes this.
  7. GKinslow
    San Antonio
    Running into a problem. Sterling McCall has no ETA on new battery pack. Back ordered. How is that possible if Hometown Hybrids has one in stock right now, ready to install? Are the aftermarket folks buying up the stock to sell them at a discounted price to individual owners e.g., Gen 2 new OEM $2000 total with 3yr/75K mileage warranty vs dealer out of warranty replacement @ ~$3500 plus tax with 3yr/unlimited mileage warranty?
    #47 GKinslow, Mar 29, 2018
  8. MelonPrius
    839
    516
    Nevada
    Call Toyota North America. They've helped others here with good will assistance on replacement traction batteries. You have already done the heavy lifting, but they can verify if there is indeed a shortage of batteries and can offer advice on how you can get a replacement battery sooner.
    pilotgrrl and GKinslow like this.
  9. GKinslow
    San Antonio
    Contacted my local dealer (Cavender) who's footing the bill to ask about their inventory. Also out of stock, estimate 7-10 business days to get one, stated 31 batteries are currently in transit from California to the Toyota Houston distribution center, all as a result of orders, so it may be that one of those is destined for my car, as Sterling McCall has 28 on backorder. Will call them back tomorrow, as they had requested I call before 5pm local time to get a verification from the center. If that's the case I have no worries. Otherwise, according to Cavender, there are two other dealerships in San Antonio with the batteries in stock, might be possible to ship one to Houston from their inventory. But I won't learn any more this evening.
    #49 GKinslow, Mar 29, 2018
  10. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    Yea, not.
    Maybe, just maybe a trade would be worth $3500 and that would be to a dealer who REALLY wanted it. No dealer with any hybrid experience would touch a 10+ YO hybrid anything for KBB pricing and most in TX will be UNDER NADA trade, often by 50%.
    #50 05PreeUs, Mar 29, 2018
  11. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    From my anecdotal evidence seeing the constants threads here, I think gen 2 batteries are beginning to fail at a tremendous rate so I'll say the dealership(s) reasonings pass my sniff test. For right now. :coffee:
  12. GKinslow
    San Antonio
    So the failure rate is increasing because they've reached or surpassed their life expectancy, putting a strain on the replacement logistics chain. If that's the case, I'm very lucky in the way they resolved this. As has been noted earlier, maybe my car shouldn't have even been offered for sale at all without the caution that the HV battery was on borrowed time. They expected it would fail, just not as quickly as it did. I wonder if that's the real reason they coughed it up.
    #52 GKinslow, Mar 29, 2018
  13. JC91006
    JC91006 Senior Member
    16,761
    8,562
    This out of stock situation is bad for the marketplace. Demand will push up the price
    rbdigital likes this.
  14. MelonPrius
    839
    516
    Nevada
    Good points, but there are too many unknowns. Assuming the PO purchased a new Toyota at the time of the trade in:
    If the PO insisted that her Prius be included in the sale as a trade in, then there's an excellent chance the dealership accepted it. If the PO was savvy about the trade in price, she would have received something closer to book value for a trade in. If the PO paid close to retail price for her new Toyota, then her trade in price would have had more wiggle room to be increased. Again, a lot of variables.
  15. GKinslow
    San Antonio
    So, no confirmation of an ETA for the HV battery, but they do expect it by sometime next week. In the meantime, Cavender Toyota stepped up and they're paying for a rental car for my daughter until the Prius is ready to go. That's far above and beyond.
    dolj and Prodigyplace like this.
  16. dolj
    dolj Senior Member
    8,428
    4,285
    It is good to hear of a positive dealer experience. So many negative ones out there.
  17. 05PreeUs
    1,097
    564
    MSP
    Thanks for that update, should have taken the drive to SA to purchase our RAV4 as Cavender sounds like a reputable dealer.... unlike, well, seeming EVERY one in the DFW area :(
    pilotgrrl likes this.
  18. HBS
    HBS Member
    74
    56
    MO
    I blocked that guy a long time ago...and would advise you to do the same!
  19. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    I bought my Gen 4 when I still lived in Chicago.
    I went to Toyota of Plano for my first Toyota Care, never went back. They're jerks.
    I go to Toyota of Richardson, who are good to work with. But, I'll be looking for a certified independent hybrid mechanic soon. I'd rather not be tied down to a dealer.
  20. Klassic
    Klassic New Member
    Jamaica
    I recently bought a Honda civic hybrid 2009 and already having some problems. After driving 10 mins or so the IMA light comes on and stay on ontil the car shut off. Then the problem comes back again after restarting the car. If I am driving up on a hill it's work perfectly fine but once I stop the car while going up the hill the car won't move even when I presses the gas.
