Steering Wheel Damper
Discussion in 'Prius c Accessories and Modifications' started by B2FiNiTY, May 28, 2013.
  1. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
  2. lachrisb
    lachrisb Junior Member
    35
    Los Angeles
    Hmm, that's an interesting part... Wonder if a normal pri one would fit? I wonder how it works? When I saw steering dampener I was thinking it would be a shock absorber of sorts...
  3. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    It looks like a tuned mass/spring combo arranged to absorb vibrations along the axis of the steering column. The leaf spring mounts indicate it would be tuning out structural vibrations along the axis of the steering column, not input from the front wheels.
  4. lachrisb
    35
    Los Angeles
    Ahh... It all makes sense now. I had the image of the old setup on my 85 Benz. I would still be interested to know how it changes the feel of the car.
  5. Aqua2014owner
    Aqua2014owner New Member
    29
    Karachi Pakistan
    2014 Aqua
    My Aqua 2014 has slight rattling sound felt in the steering when driving on small sharp edged potholes, is this thing going to help, anyone with technical help please.
  6. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    I dont think so. If the rattle is from the steering tube then the only solution would be to get the tube with new bushes.
    Get your car checked from some expert alignment shop, they will put the car on lift and then hold the wheel and shake it to hear for any noise.
    If your car is high milage only then you should have this problem.
  7. Aqua2014owner
    29
    Karachi Pakistan
    2014 Aqua
    My car has only 42000 Km on Odo. can you name a reliable workshop please.
  8. Aqua2014owner
    29
    Karachi Pakistan
    2014 Aqua
    I had spacers installed , 1 inch in front & 1 1/2 inch back could this be the cause, people with spacers say they never had this problem. please name a workshop in Karachi.Thanks
  9. Adeel96
    Adeel96 New Member
    Karachi, Pakistan
    2014 Aqua
    He
    Hello fellow Karachi resident. There is a workshop on main Jamshed road, just before PSO pump named FALAK AUTOS . Arshad Sahab will be there. They deal in suspension, coilovers and axles. It is a very reliable workshop.
  10. Aqua2014owner
    29
    Karachi Pakistan
    2014 Aqua
    Thanks, I will I A.
