2018 Prius Prime finally showing actual MPG?
Discussion in 'Prime Main Forum (2017-2022)' started by Darken, Apr 3, 2018.
  1. Darken
    Darken Active Member
    553
    49
    PA Dutch Country
    Didn't see a thread on this so I thought I would make a post. On another board I've seen posts from a few 2018 owners that the MFD now shows MPG greater then the 2017's maxed 199.9. Can anyone who owns one verify if this is the case or not?
    If so what are the odds that they may update the 2017 version to get rid of the 199.9 MPG cap?
    muleman likes this.
  2. Prodigyplace
    12,683
    11,833
    Central Virginia
    The odds are slim to none. The only reason I could think of would be if there was some other reason to update that part of the software and adding that feature made Toyota's software version maintenance easier & less expensive.
    I cannot think of any other way Toyota could profit from making such a change.
  3. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    No profit opportunity, but still opportunity.
    You can have the FOB updated, upon request. I did for the "open all windows" feature.
    Toyota updated the buttons on the steering-wheel in the past, providing a software update just for driver convenience.
  4. Prodigyplace
    12,683
    11,833
    Central Virginia
    I just looked at my Gen 4. I suspect it would need a different speedometer display, much like the early Gen 4 needed to switch to Km. there does not look like any space for a digit wider than 1.
  5. muleman
    muleman Junior Member
    56
    49
    rochester ny
    I want this. I have been pinned on 199.9 for a while.
    #5 muleman, Apr 4, 2018
  6. pineprius
    pineprius 15th Hole #4
    245
    134
    NC
    I've been pinned on 199.9 per trip A on a tank of gas, so I just changed the ODO to total miles on car and voila 115.9 mpg for 4500 miles.
    muleman likes this.
  7. Travis64
    Travis64 Member
    Ny
    Who would buy a 18 when the 17 is the same car but so much cheaper
  8. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    I have a ScanGauge2 and it seems to show the actual MPG. So the computer may have the info but only displays up to 199.9.
  9. john1701a
    12,833
    5,310
    58
    Diminishing returns... there simply isn't much benefit of values over 200 MPG, especially when margin-of-error is considered.
    Dudley1030 likes this.
  10. Stever56
    Stever56 Junior Member
    US Crestwood, illinois
  11. Tideland Prius
    16,623
    It also fluctuates quite a bit above 200mpg but the actual usage of fuel isn't that great.
    Nic Steussy likes this.
  12. Darken
    553
    49
    PA Dutch Country
    A valid point but it really depends on where you live. Out west I duobt there are many if any 2017's left, whereas here in the east you can have your pick of 2017's with any option or style you want. Made the 2017 choice a no brainer for me, but others may not have that option.
  13. JGC61
    JGC61 Active Member
    216
    104
    Long Island
    Fill my tank every 500 miles.
    Last time I used 1.5 gallons of fuel.
    That's about 348 MPG.
    benagi and Dudley1030 like this.
  14. alexcue
    alexcue Active Member
    346
    311
    So Cal
    agree, the actual calculated has never been accurate on a Prius IMO.
  15. fneil
    fneil Member
    71
    52
    Carrboro, NC
    I've never really understood why anyone cares about the >199 mpg readout. When you're driving mixed EV/gas miles, it's pretty much meaningless, as it doesn't factor in the $$$'s/carbon contributed by the EV/charging component.
    The only time my mpg readout means anything is when I'm running in pure HV mode. If I reset the tripmeter, and run in HV mode, I get a true mpg indication. But I often forget to switch back to HV from default EV mode after a stop, and then my mpg calculation is toast. I really wish the HV/EV mode selector was persistent.
    Which is why I don't bother running Fuelly stats with my Prime - meaningless...
